Verizon SIM with static IP on EM7455
I am unable to use a Verizon SIM (WCDMA) with Static IP on EM7455. It does not get registered on network.
I have tested EM7455 with T-Mobile Static SIM that selects LTE mode and it is working fine (registration, data connection etc).
Firmware - PRI FF GOOD 0 0 0 002.079_001 02.33.03.00_VERIZON
Status:
Current Time: 158 Temperature: 32
Reset Counter: 1 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 2100
WCDMA channel: 10668
GMM (PS) state:DEREGISTERED LIMITED SERVICE
MM (CS) state: IDLE LIMITED SERVICE
WCDMA L1 state:L1M_PCH_BPLMN LAC: 9E20 (40480)
RRC state: DISCONNECTED UTRAN Cell ID: 0901C08B (151109771)
RxM RSSI C0: -89 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
Is there any way to make it work with WCDMA SIM?
Could you help to provide the output of these commands:
  • AT+COPS=?
  • AT!BAND?
  • AT+CGDCONT?
If these commands show incorrect band/apn, please help to set the correct one.
The status showed Limited Service, so could you help to check your SIM card? Is it working with other devices?
at+cops?
+COPS: 0
at!entercnd=“A710”
AT!BAND?
Index, Name, GW Band Mask L Band Mask TDS Band Mask
0A, All bands minus B30, 0002000007C00000 00000100130818DF 0000000000000000
AT+CGDCONT?
+CGDCONT: 1,“IP”,“vzwinternet”,“0.0.0.0”,0,0,0,0
@akn
I am a little confused by the fact you are stating that you are using a Verizon WCDMA SIM, WCDMA is AKA 3G and Verizon don’t have a 3G network, only LTE.
It is a 4G SIM. All the 3G and 4G bands were enabled in current modem setting. With the Verizon Static SIM, it was always trying 3G only bands and going into deep sleep mode. Due to this I misinterpreted it as 3G SIM.
It worked after selecting LTE only networks
AT!SELRAT=06 or AT!BAND=9
