My Verizon SIM fails to register with band setting set to “00, All bands”.
It only works if I select “09, LTE ALL”.
“All bands” include 4G bands and the SIM should register with “00, All bands”.
What may be the root case of this problem?
Assuming that the unit can see the network (so the right band is selected then the lack of attach will have nothing to do with it. Can you use the attached teraterm script (its a zipped up text file) get the status of the unit and we can figure out what the issue is? I suggest you post the response as a file and not directly in a post (if you do it as code so it is not too long and contained in a sub window).
MC-EM status.zip (445 Bytes)
ati
Model: EM7455
Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
MEID: A000005368D949
ESN: 12807986565, 8079DD85
IMEI: 359073061394304
IMEI SV: 20
FSN: LF833224780210
+GCAP: +CGSM
at+cmee=1
at!priid?
PRI Part Number: 9907469
Revision: 001.000
Customer: Generic-M2M
Carrier PRI: 9999999_9904780_SWI9X30C_02.33.03.00_00_VERIZON_002.079_001
at!image?
FW 1 GOOD 132 0 0 ?? 02.24.05.06?
FW 2 GOOD 1 0 0 ?? 02.24.03.00?
FW 3 GOOD 133 0 0 ?? 02.33.03.00?
FW 4 GOOD 127 0 0 ?? 02.32.11.00?
Max FW images: 4
Active FW image is at slot 3
PRI FF GOOD 0 0 0 002.027_000 02.24.05.06_ATT
PRI FF GOOD 0 0 0 002.026_000 02.24.05.06_GENERIC
PRI FF GOOD 0 0 0 002.022_000 02.24.03.00_SPRINT
PRI FF GOOD 0 0 0 002.079_001 02.33.03.00_VERIZON
Max PRI images: 50
at!gstatus?
!GSTATUS:
Current Time: 594 Temperature: 35
Reset Counter: 2 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 1900
WCDMA channel: 9886
GMM (PS) state:NULL —
MM (CS) state: IDLE LIMITED SERVICE
WCDMA L1 state:L1M_PCH_SLEEP LAC: 6699 (26265)
RRC state: DISCONNECTED UTRAN Cell ID: 0606A42B (101098539)
RxM RSSI C0: -93 RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
at+cpin?
+CPIN: READY
at+cimi
311480165304487
at!pcinfo?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
LPM persistence - None
at!custom?
!CUSTOM:
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
DHCPRELAYENABLE 0x01
SINGLEAPNSWITCH 0x01
at+creg?
+CREG: 0,2
at+cgreg?
+CGREG: 0,2
at+cereg?
+CEREG: 0,2
at+cgpaddr=1
+CGPADDR: 1,0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
at!selrat?
!SELRAT: 00, Automatic
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at!uims?
!UIMS: 1
AT!HWID?
ERROR
at!impref?
!IMPREF:
preferred fw version: 00.00.00.00
preferred carrier name: AUTO-SIM
preferred config name: AUTO-SIM_000.000_000
preferred subpri index: 000
current fw version: 02.33.03.00
current carrier name: VERIZON
current config name: VERIZON_002.079_001
current subpri index: 000
at!band?
Index, Name
00, All bands
at!entercnd=“A710”
at!band?
Index, Name, GW Band Mask L Band Mask TDS Band Mask
00, All bands, 0002000007C00000 000000000000101A 0000000000000000
at!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0000010D (diag,nmea,modem,rmnet0)
at+cops?
+COPS: 0
at+cops=?
+cops: (1,"Verizon ","Verizon ",“311480”,7),(1,“Extended Network”,“Extended”,“310410”,7),(1,“313 100”,“313 100”,“313100”,7),(1,“Extended Network”,“Extended”,“310410”,2),(3,“T-Mobile”,“T-Mobile”,“310260”,2),(0,1,2,3,4),(0,1,2)
AT!HWID?
Revision: 1.0
OKEM_MC_status_20201001-214443.log.txt (8.5 KB)
