Hi @jyijyi ,
I think it can work.
I saw result like below:
So I want to find what problem in my APP.
Do you have some hint for this?
Hi @jyijyi ,
Again as before, for debugging, the easiest way is you port your app to the working one and see which line makes the problem.
Hi @jyijyi ,
I try to modify helloWorld to test
my .adef
sandboxed: false
start: manualexecutables:
Larrytest = ( larryComponent )
}processes:
envVars:
LE_LOG_LEVEL = DEBUG
}run: { ( Larrytest ) }}
my .cdef
sources:
larrytest.c
and my .c
#include “legato.h”
COMPONENT_INIT
LE_INFO(“Num of arg %d”, le_arg_NumArgs());
Then I got result
Aug 2 07:01:23 fx30 user.warn Legato: -WRN- | supervisor[835]/supervisor T=main | proc.c GetWatchdogAction() 359 | larrytest watchdogAction ‘’ in proc section
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxCoreDumpFileBytes to value 8192.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxFileBytes to value 90112.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxLockedMemoryBytes to value 8192.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxFileDescriptors to value 256.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxMQueueBytes to value 512.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxThreads to value 20.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | resourceLimits.c SetRLimitValue() 282 | Setting resource limit maxQueuedSignals to value 100.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | proc.c proc_Start() 1389 | Starting process ‘larrytest’ with pid 12243
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[12243]/supervisor T=main | proc.c proc_Start() 1354 | Execing ‘larrytest’
Aug 2 07:01:23 fx30 user.emerg Legato: EMR | supervisor[12243]/supervisor T=main | proc.c proc_Start() 1366 | Could not exec ‘larrytest’. No such file or directory.
Aug 2 07:01:23 fx30 user.info Legato: INFO | supervisor[835]/supervisor T=main | proc.c proc_SigChildHandler() 2035 | Process ‘larrytest’ (PID: 12243) has exited with exit code 1.
Aug 2 07:01:23 fx30 user.warn Legato: -WRN- | supervisor[835]/supervisor T=main | app.c app_SigChildHandler() 3480 | Process ‘larrytest’ in app ‘larrytest’ faulted: Ignored.
Aug 2 07:01:24 fx30 user.warn Legato: -WRN- | posDaemon[938]/le_pa_gnss T=unknown | pa_gnss_qmi.c PositionHandler() 1359 | Bad position indication
my command is
app runProc larrytest larrytest --exe=larrytest – 123456 122343 “test” "treas
Does there have something wrong ?
maybe you can directly use the sendComponent here which has proven to be working fine:
Hi @jyijyi ,
OK, I will try it. Thanks
I have other question about use .api
I modemDemo use le_mdc.api, so I try to it but my folder is in “/home/” not like “sample” folder.
But I put my test into sample folder then I can use “le_mdc.api”, so I want to know how can I read the api when my folder is in “/home” (I can compiled but when I run app It will fault.)
do you use the makefile to compile?
then why don’t you put in the sample folder for compilation if it is working fine?
Hi @jyijyi ,
Because I want to know how to use it properly.
Then I got the error log:
Aug 2 07:57:03 fx30 user.emerg Legato: EMR | supervisor[7078]/supervisor T=main | proc.c ConfigNonSandboxedProcess() 988 | Could not change working directory to ‘/legato/systems/current/appsWriteable/larrytest’. No such file or directory
when I create the folder then other error will show
Aug 2 08:00:22 fx30 user.err Legato: =ERR= | serviceDirectory[1241]/serviceDirectory T=main | serviceDirectory.c DispatchToServer() 713 | Client (uid 0 ‘root’, pid 7556) disagrees with server (uid 0 ‘root’, pid 1367) on protocol ID of service 'Larrytest.larryCompo
Aug 2 16:00:22 fx30 user.emerg Legato: EMR | UNKNOWN[7556]/framework T=main | messagingSession.c ReceiveSessionOpenResponse() 699 | Unexpected server response: -6 (LE_FAULT).
I have no idea…
I also put in the sample folder instead of /home to compile.
Maybe you can do the same as you found that it is working fine.
Hi @jyijyi ,
I try to compile “mdcIntegrationTest” but I got error
error: implicit declaration of function ‘le_mdc_GetDisconnectionReasonExt’ [-Werror=implicit-function-declaration]
LE_PRINT_VALUE(“%d”, le_mdc_GetDisconnectionReasonExt(profileRef, LE_MDC_PDP_IPV4));
How to I fix it?
I also try to include le_mdc_common.h and le_mdc_interface.h but I can’t find the files.
please see here to add something like “-C -Wno-error=implicit-function-declaration”:
For those files, you can search in legato.io:
Hi @jyijyi ,
I added “-C -Wno-error=implicit-function-declaration” then I got other error
_build_mdcTest/wp76xx/staging/read-only/lib/libComponent_mdcTestComp.so: undefined reference to
le_mdc_GetPlatformSpecificDisconnectionCodeExt' _build_mdcTest/wp76xx/staging/read-only/lib/libComponent_mdcTestComp.so: undefined reference tole_mdc_GetDisconnectionReasonExt’
I don’t see problem to compile the application with mdcTest.adef :
mkapp -t wp76xx -o Target_Legato_Debug -w Target_Legato_Debug -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/atServices" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/airVantage/legacy" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/watchdog" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/portService" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/supervisor" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/logDaemon" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/positioning" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/secureStorage" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/wifi" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/modemServices" -i "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/interfaces/airVantage" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/dataConnectionService/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/test/watchdogChain" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/apps/platformServices/airVantageConnector" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/airVantage" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/modules/WiFi/apps/tools/wifi" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/positioning" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/secStore" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/uartMode/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/portService" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/modemServices/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/audio/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/apps/tools" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/3rdParty" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/fwupdate/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/dataConnectionService" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/modules/WiFi/service" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/airVantage/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/fwupdate" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/positioning/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/devMode" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/secStore/platformAdaptor/default" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/apps/platformServices/mqttClient" -s "." -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/atServices" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/modemServices" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components" -s "/home/owner/legato/packages/legato.framework.19.2.0.wp76xx-201906171244/resources/legato/components/uartMode" -C -g -X -g -L -g mdcTest.adef
[1/11] Compiling C source
[2/11] Compiling C source
[3/11] Generating IPC interface code
[4/11] Compiling C source
[5/11] Compiling C source
[6/11] Linking C library
[7/11] Bundling file
[8/11] Linking C executable
[9/11] Bundling file
[10/11] Creating info.properties
[11/11] Packaging app
Hi @jyijyi ,
I use “mkapp -v -t $@ -C -Wno-error=implicit-function-declaration
-i $(LEGATO_ROOT)/interfaces/modemServices
mdcTest.adef”
So what path must be include?
I don’t know, you might use my command line
Hi @jyijyi ,
OK, I will try it. Thanks!!!
Hi @jyijyi ,
I try to modify the path then it work.
But I put it into device then run it. I got error.
Aug 3 07:51:56 fx30 user.err Legato: =ERR= | serviceDirectory[850]/serviceDirectory T=main | serviceDirectory.c DispatchToServer() 713 | Client (uid 0 ‘root’, pid 16636) disagrees with server (uid 0 ‘root’, pid 931) on protocol ID of service 'mdcTest.mdcTestComp.l
Aug 3 07:51:56 fx30 user.emerg Legato: EMR | UNKNOWN[16636]/framework T=main | LE_FILENAME ReceiveSessionOpenResponse() 684 | Unexpected server response: -6 (LE_FAULT).
Aug 3 07:51:56 fx30 user.info Legato: INFO | supervisor[839]/supervisor T=main | proc.c proc_SigChildHandler() 2035 | Process ‘mdcTest’ (PID: 16636) has exited with exit code 1.
Aug 3 07:51:56 fx30 user.warn Legato: -WRN- | supervisor[839]/supervisor T=main | app.c app_SigChildHandler() 3480 | Process ‘mdcTest’ in app ‘mdcTest’ faulted: Ignored.
Just like I put sample to the /home/, but this time I put it in the sample.
it seems the legato version compiled for the app is not matching with actual legato version in the module
Hi @jyijyi
How to I check this ?
I compile use leaf shell and my FX30 FW version is “fx30_wp76xx_full_r10.1.1.004-generic.cwe”
Should I get the same version legato source ?
