awneil
August 19, 2014, 10:15pm
#1
Well, at long last I’ve found some time to sit down with the USB stick and Dev Kit and get it all fired up.
The USB stick and the instructions on legato.io are certainly a great help!
I have the Host system running, and can connect to the target by serial & by SSH/ethernet.
But I can’t do the next step:
Legato > Use Legato > Get Started > Quick Start > Setup Target:
Run this to copy the Legato framework libraries and executables onto the target, and start the Legato runtime components:
$ instlegato build/wp7
legato.io/legato-docs/14_07/ … arget.html
I run the command, and it just says,
An ‘instlegato’ script does exist in legato/legato-14.04.0.Beta.rc3/framework/tools/scripts
Is it just a matter of giving the full path to the script, or have I missed some other setup
esun
August 20, 2014, 2:02am
#2
You will need to source the environment for Legato. Go to the Legato directory and run ‘bin/legs’ as mentioned in legato.io/legato-docs/14_07/ … uildLegato
You’ll need to run this every time you open a new shell.
Oh and just in case you haven’t done so, you might want to pull the latest version of Legato since the USB stick only contains the previous release
awneil
August 20, 2014, 6:24am
#3
Sorry - what does that mean?
I’m a complete newbie when it comes to Linux!
When I do that:
ubuntu@ubuntu:~$ cd legato
ubuntu@ubuntu:~/legato$ bin/legs
bash: bin/legs: No such file or directory
ljweko
August 20, 2014, 10:03am
#4
I don’t know if previous versions of framework needed extra directory level, as I here have only:
Anyway, try this:
legato-14.04.0.Beta.rc3/bin/legs
or get rid of extra directory level or cd to legato-14.04.0.Beta.rc3/.
awneil
August 20, 2014, 2:20pm
#5
Result:
ubuntu@ubuntu:~/legato$ legato-14.04.0.Beta.rc3/bin/legs
Using legato framework found under '/home/ubuntu/legato/legato-14.04.0.Beta.rc3'
ubuntu@ubuntu:~/legato$ source "/home/ubuntu/legato/legato-14.04.0.Beta.rc3/bin/configlegatoenv"
***ERROR: '/home/ubuntu/legato' doesn't look like the root directory of a Legato repository.
ubuntu@ubuntu:~/legato$ exec <> /dev/tty
awneil
August 20, 2014, 2:28pm
#6
Result:
ubuntu@ubuntu:~/legato$ cd legato-14.04.0.Beta.rc3
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ bin/legs
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ source "/home/ubuntu/legato/legato-14.04.0.Beta.rc3/bin/configlegatoenv"
AR7_TOOLCHAIN_DIR set to default (/opt/swi/y14-ext/tmp/sysroots/x86_64-linux/usr/bin/armv7a-vfp-neon-poky-linux-gnueabi).
WP7_TOOLCHAIN_DIR set to same as AR7_TOOLCHAIN_DIR (/opt/swi/y14-ext/tmp/sysroots/x86_64-linux/usr/bin/armv7a-vfp-neon-poky-linux-gnueabi).
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ exec <> /dev/tty
Is that good
awneil
August 20, 2014, 4:09pm
#7
OK, having done that, the instlegato command is now recognised - but doesn’t work:
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ instlegato build/wp7 fd11:2233:4455:1:a84d:bcff:fe34:3b39
ping: unknown host fd11:2233:4455:1:a84d:bcff:fe34:3b39
***ERROR: Device address fd11:2233:4455:1:a84d:bcff:fe34:3b39 seems to be unreachable.
This appears to be because instlegato is using ping - which requires an IPv4 address - but the target is only telling me IPv6 addresses
See: https://forum.sierrawireless.com/t/target-shows-only-ipv6-address/11951/1
awneil
August 20, 2014, 9:57pm
#8
in which we find that the IPv4 address is 192.168.0.13 and, with that, instlegato does seem to work OK:
[code]ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ bin/legs
Using legato framework found under ‘/home/ubuntu/legato/legato-14.04.0.Beta.rc3’
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ source “/home/ubuntu/legato/legato-14.04.0.Beta.rc3/bin/configlegatoenv”
ubuntu@ubuntu:~/legato/legato-14.04.0.Beta.rc3$ instlegato build/wp7 192.168.0.13
root@192.168.0.13 ’s password:
Stopping Legato…
DONE.
/usr/local/lib:
libyajl.so -> libyajl.so
libappCfgInstallDefault.so -> libappCfgInstallDefault.so
libreturncodes.so -> libreturncodes.so
libappCfgRemoveDefault.so -> libappCfgRemoveDefault.so
libSwi_AirVantage.so -> libSwi_AirVantage.so
libSwi_DeviceTree.so -> libSwi_DeviceTree.so
lible_tree_hdlr.so -> lible_tree_hdlr.so
libSwi_DSet.so -> libSwi_DSet.so
libEmp.so -> libEmp.so
libSwi_log.so -> libSwi_log.so
liblegato.so -> liblegato.so
lible_pa.so -> lible_pa.so
lible_pa_gnss.so -> lible_pa_gnss.so
lible_mdm_services.so -> lible_mdm_services.so
lible_mdm_client.so -> lible_mdm_client.so
lible_pos_services.so -> lible_pos_services.so
lible_pos_client.so -> lible_pos_client.so
lible_pa_audio.so -> lible_pa_audio.so
lible_audio_services.so -> lible_audio_services.so
lible_audio_client.so -> lible_audio_client.so
lible_data_client.so -> lible_data_client.so
lible_cellnet_client.so -> lible_cellnet_client.so
lible_cfg_api.so -> lible_cfg_api.so
lible_cfgAdmin_api.so -> lible_cfgAdmin_api.so
libappConfig.so -> libappConfig.so
lible_sup_api.so -> lible_sup_api.so
/lib:
libgcc_s.so.1 -> libgcc_s.so.1
libuuid.so.1 -> libuuid.so.1.3.0
libm.so.6 -> libm-2.17.so
libanl.so.1 -> libanl-2.17.so
libresolv.so.2 -> libresolv-2.17.so
libnsl.so.1 -> libnsl-2.17.so
libncursesw.so.5 -> libncursesw.so.5.9
libthread_db.so.1 -> libthread_db-1.0.so
ld-linux.so.3 -> ld-2.17.so
libutil.so.1 -> libutil-2.17.so
libpthread.so.0 -> libpthread-2.17.so
libnss_compat.so.2 -> libnss_compat-2.17.so
libBrokenLocale.so.1 -> libBrokenLocale-2.17.so
libc.so.6 -> libc-2.17.so
libdl.so.2 -> libdl-2.17.so
libnss_files.so.2 -> libnss_files-2.17.so
libtinfo.so.5 -> libtinfo.so.5.9
librt.so.1 -> librt-2.17.so
libnss_dns.so.2 -> libnss_dns-2.17.so
libblkid.so.1 -> libblkid.so.1.1.0
libcrypt.so.1 -> libcrypt-2.17.so
/usr/lib:
libpython2.7.so.1.0 -> libpython2.7.so.1.0
libdsutils.so.1 -> libdsutils.so.1.0.0
liburcu-mb.so.1 -> liburcu-mb.so.1.0.0
libz.so.1 -> libz.so.1.2.7
libqmi.so.1 -> libqmi.so.1.0.0
libqmi_client_qmux.so.1 -> libqmi_client_qmux.so.1.0.0
liburcu-signal.so.1 -> liburcu-signal.so.1.0.0
liburcu-bp.so.1 -> liburcu-bp.so.1.0.0
libloc_adapter_so.so.1 -> libloc_adapter_so.so.1.0.0
libloc_api.so.1 -> libloc_api.so.1.0.0
libqcmap_cm.so.1 -> libqcmap_cm.so.1.0.0
libkmod.so.2 -> libkmod.so.2.1.3
libnetmgr.so.0 -> libnetmgr.so.0.0.0
libqmi_sap.so.1 -> libqmi_sap.so.1.0.0
libalsa_intf.so.1 -> libalsa_intf.so.1.0.0
libxml.so.0 -> libxml.so.0.0.0
libgps_utils_so.so.1 -> libgps_utils_so.so.1.0.0
liblttng-ust-ctl.so.1 -> liblttng-ust-ctl.so.1.0.0
libglib-2.0.so.0 -> libglib-2.0.so.0.3400.3
libgio-2.0.so.0 -> libgio-2.0.so.0.3400.3
libgobject-2.0.so.0 -> libgobject-2.0.so.0.3400.3
liblttng-ust-tracepoint.so.0 -> liblttng-ust-tracepoint.so.0.0.0
libcutils.so.0 -> libcutils.so.0.0.0
liburcu-qsbr.so.1 -> liburcu-qsbr.so.1.0.0
libaudioalsa.so.1 -> libaudioalsa.so.1.0.0
libacdbloader.so.1 -> libacdbloader.so.1.0.0
libqmi_cci.so.1 -> libqmi_cci.so.1.0.0
libqmi_csi.so.1 -> libqmi_csi.so.1.0.0
liburcu.so.1 -> liburcu.so.1.0.0
libqmi_encdec.so.1 -> libqmi_encdec.so.1.0.0
libdssnew.so.1 -> libdssnew.so.1.0.0
libqmiservices.so.1 -> libqmiservices.so.1.0.0
libreadline.so.6 -> libreadline.so.6.2
libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.3400.3
liblttng-ust-fork.so.0 -> liblttng-ust-fork.so.0.0.0
liburcu-cds.so.1 -> liburcu-cds.so.1.0.0
libdsnet.so.1 -> libdsnet.so.1.0.0
libqmiidl.so.1 -> libqmiidl.so.1.0.0
libdsstest.so.1 -> libdsstest.so.1.0.0
liblttng-ust-libc-wrapper.so.0 -> liblttng-ust-libc-wrapper.so.0.0.0
liblttng-ust.so.0 -> liblttng-ust.so.0.0.0
libdiag.so.1 -> libdiag.so.1.0.0
libaudcal.so.1 -> libaudcal.so.1.0.0
liblog.so.0 -> liblog.so.0.0.0
liburcu-common.so.1 -> liburcu-common.so.1.0.0
libqmi_common_so.so.1 -> libqmi_common_so.so.1.0.0
libhistory.so.6 -> libhistory.so.6.2
libgthread-2.0.so.0 -> libgthread-2.0.so.0.3400.3
libstdc++.so.6 -> libstdc++.so.6.0.17
libffi.so.6 -> libffi.so.6.0.0
libacdbmapper.so.1 -> libacdbmapper.so.1.0.0
libqcci_legacy.so.1 -> libqcci_legacy.so.1.0.0
libconfigdb.so.0 -> libconfigdb.so.0.0.0
DONE.
[/code]
awneil
August 26, 2014, 11:11pm
#9
awneil:
Is that good
Yes - that is good!
Also managed to build, install & run the modemDemo - and exchange text messages with my phone
Hi guys…i m stuck with the same issue of instlegato command…the output after running instlegato command is:
user@user-OptiPlex-9020:~/legato-af$ bin/legs
Using legato framework found under '/home/user/legato-af'
user@user-OptiPlex-9020:~/legato-af$ export PATH=/home/user/legato-af/bin:/home/user/legato-af/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/bin:/home/user/legato-af/bin:/home/user/legato-af/bin:/home/user/legato-af/bin:/home/user/legato-af/bin/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/bin:/home/user/Sierra/LegatoYocto1501/poky/scripts:/home/user/Sierra/LegatoYocto1501/poky/bitbake/bin:/usr/local/bin:/bin:/usr/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/build/localhost/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/build/localhost/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/build/localhost/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/build/localhost/bin:/home/user/legato-af/bin/build/localhost/bin:/home/user/legato-af/build/localhost/bin:/home/user/legato-af/build/localhost/bin:/home/user/legato-af/build/localhost/bin:/home/user/Sierra/LegatoYocto1501/build_bin/tmp/work/x86_64-linux/legato-tools/git-r0/git/build/localhost/bin:/home/user/legato-af/build/localhost/bin:/home/user/legato-af/build/localhost/bin
user@user-OptiPlex-9020:~/legato-af$ source /home/user/legato-af/framework/tools/scripts/configToolchainDirEnvVars
user@user-OptiPlex-9020:~/legato-af$ exec <> /dev/tty
user@user-OptiPlex-9020:~/legato-af$ instlegato build/wp7 10.20.34.140
Installing Legato framework from: build/wp7
root@10.20.34.140's password:
Legato wasn't running.
DONE.
Cleaning...
Checking target environment...
Unpacking...
Updating dynamic linker configuration...
/usr/local/lib:
libComponent_audioPlaybackRecExe.so -> libComponent_audioPlaybackRecExe.so
libIF_testCellNetService.cellNetService.le_cellnet.so -> libIF_testCellNetService.cellNetService.le_cellnet.so
libIF_cm.cm.le_mdc.so -> libIF_cm.cm.le_mdc.so
libIF_configDelete.configDelete.le_cfg.so -> libIF_configDelete.configDelete.le_cfg.so
libIF_cm.cm.le_sim.so -> libIF_cm.cm.le_sim.so
libIF_configTree.configTree.le_cfgAdmin.so -> libIF_configTree.configTree.le_cfgAdmin.so
libIF_supervisor.supervisor.le_sup_state.so -> libIF_supervisor.supervisor.le_sup_state.so
libIF_appCfgRemove.appConfig.le_cfg.so -> libIF_appCfgRemove.appConfig.le_cfg.so
libIF_le_info_client.so -> libIF_le_info_client.so
libIF_execInApp.execInApp.le_sup_state.so -> libIF_execInApp.execInApp.le_sup_state.so
libComponent_logDaemon.so -> libComponent_logDaemon.so
libIF_testAudioMccExe.audioMccExe.le_mcc_call.so -> libIF_testAudioMccExe.audioMccExe.le_mcc_call.so
libIF_watchdog.watchdog.le_sup_wdog.so -> libIF_watchdog.watchdog.le_sup_wdog.so
libIF_testPosDaemon.posDaemonTest.le_posCtrl.so -> libIF_testPosDaemon.posDaemonTest.le_posCtrl.so
libComponent_cdmaPduTest.so -> libComponent_cdmaPduTest.so
libIF_execInApp.security.le_cfg.so -> libIF_execInApp.security.le_cfg.so
libIF_cm.cm.le_mrc.so -> libIF_cm.cm.le_mrc.so
libIF_appSetFilePermissions.security.le_cfg.so -> libIF_appSetFilePermissions.security.le_cfg.so
libIF_testAudioDtmf.dtmfTest.le_audio.so -> libIF_testAudioDtmf.dtmfTest.le_audio.so
libComponent_posCtrlTest.so -> libComponent_posCtrlTest.so
libComponent_appConfig.so -> libComponent_appConfig.so
libIF_configDelete.configDelete.le_cfgAdmin.so -> libIF_configDelete.configDelete.le_cfgAdmin.so
libIF_testPosDaemon.posDaemon.le_pos.so -> libIF_testPosDaemon.posDaemon.le_pos.so
libIF_configDropWriteExe.configDropWrite.le_cfg.so -> libIF_configDropWriteExe.configDropWrite.le_cfg.so
libComponent_cm.so -> libComponent_cm.so
libIF_fwupdate.fwupdate.le_info.so -> libIF_fwupdate.fwupdate.le_info.so
libIF_supervisor.supervisor.le_sup_wdog.so -> libIF_supervisor.supervisor.le_sup_wdog.so
libComponent_supervisor.so -> libComponent_supervisor.so
libComponent_gdbCfg.so -> libComponent_gdbCfg.so
libComponent_filePermissions.so -> libComponent_filePermissions.so
libIF_cm.cm.le_sms.so -> libIF_cm.cm.le_sms.so
libIF_appSetFilePermissions.filePermissions.le_cfg.so -> libIF_appSetFilePermissions.filePermissions.le_cfg.so
libIF_testModemSmsDeletion.smsDeletion.le_cfg.so -> libIF_testModemSmsDeletion.smsDeletion.le_cfg.so
libIF_appCfgInstall.appConfig.le_cfg.so -> libIF_appCfgInstall.appConfig.le_cfg.so
libIF_testAudioDtmf.dtmfTest.le_mcc_call.so -> libIF_testAudioDtmf.dtmfTest.le_mcc_call.so
libIF_appCtrl.appCtrl.le_cfg.so -> libIF_appCtrl.appCtrl.le_cfg.so
libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_mcc_call.so -> libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_mcc_call.so
libIF_supervisor.security.le_cfg.so -> libIF_supervisor.security.le_cfg.so
libIF_le_mrc_client.so -> libIF_le_mrc_client.so
libIF_testAudioMccExe.audioMccExe.le_audio.so -> libIF_testAudioMccExe.audioMccExe.le_audio.so
libIF_testAudioDtmf.dtmfTest.le_cfg.so -> libIF_testAudioDtmf.dtmfTest.le_cfg.so
libIF_cm.cm.le_info.so -> libIF_cm.cm.le_info.so
libIF_smackApiTest.security.le_cfg.so -> libIF_smackApiTest.security.le_cfg.so
libComponent_userAdderRemover.so -> libComponent_userAdderRemover.so
libComponent_mccTest.so -> libComponent_mccTest.so
libComponent_configDropWrite.so -> libComponent_configDropWrite.so
libIF_gdbCfg.gdbCfg.le_cfg.so -> libIF_gdbCfg.gdbCfg.le_cfg.so
libComponent_smsTest.so -> libComponent_smsTest.so
libIF_appCtrl.appCtrl.le_sup_ctrl.so -> libIF_appCtrl.appCtrl.le_sup_ctrl.so
libIF_cm.cm.le_cfg.so -> libIF_cm.cm.le_cfg.so
libIF_sdir.sdirTool.le_cfg.so -> libIF_sdir.sdirTool.le_cfg.so
libIF_testModemMcc.mccTest.le_mcc_call.so -> libIF_testModemMcc.mccTest.le_mcc_call.so
libIF_testModemSmsDeletion.smsDeletion.le_sms.so -> libIF_testModemSmsDeletion.smsDeletion.le_sms.so
libIF_testPosDaemon.posDaemonTest.le_pos.so -> libIF_testPosDaemon.posDaemonTest.le_pos.so
libIF_testPosDaemon.posDaemon.le_cfg.so -> libIF_testPosDaemon.posDaemon.le_cfg.so
libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_mcc_profile.so -> libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_mcc_profile.so
libIF_configTree.configTree.le_cfg.so -> libIF_configTree.configTree.le_cfg.so
libComponent_dtmfTest.so -> libComponent_dtmfTest.so
libIF_appCtrl.appCtrl.le_sup_state.so -> libIF_appCtrl.appCtrl.le_sup_state.so
libComponent_sdirTool.so -> libComponent_sdirTool.so
libIF_supervisor.supervisor.le_cfg.so -> libIF_supervisor.supervisor.le_cfg.so
libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_cfg.so -> libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_cfg.so
libIF_le_pos_client.so -> libIF_le_pos_client.so
libIF_execInApp.execInApp.le_cfg.so -> libIF_execInApp.execInApp.le_cfg.so
libComponent_posDaemon.so -> libComponent_posDaemon.so
libIF_configDropReadExe.configDropRead.le_cfg.so -> libIF_configDropReadExe.configDropRead.le_cfg.so
libIF_configTestExe.configTest.le_cfg.so -> libIF_configTestExe.configTest.le_cfg.so
libIF_testAudioDtmf.dtmfTest.le_mcc_profile.so -> libIF_testAudioDtmf.dtmfTest.le_mcc_profile.so
libComponent_configTree.so -> libComponent_configTree.so
libIF_config.config.le_cfg.so -> libIF_config.config.le_cfg.so
libComponent_config.so -> libComponent_config.so
libComponent_security.so -> libComponent_security.so
libIF_le_posCtrl_client.so -> libIF_le_posCtrl_client.so
libIF_testPosCtrl.posCtrlTest.le_posCtrl.so -> libIF_testPosCtrl.posCtrlTest.le_posCtrl.so
libIF_fwupdate.fwupdate.le_fwupdate.so -> libIF_fwupdate.fwupdate.le_fwupdate.so
libIF_configTestExe.configTest.le_cfgAdmin.so -> libIF_configTestExe.configTest.le_cfgAdmin.so
libIF_le_mdc_client.so -> libIF_le_mdc_client.so
libIF_watchdog.watchdog.le_wdog.so -> libIF_watchdog.watchdog.le_wdog.so
libComponent_cfgTest.so -> libComponent_cfgTest.so
libComponent_cellNetService.so -> libComponent_cellNetService.so
libComponent_posDaemonTest.so -> libComponent_posDaemonTest.so
libIF_testAudioMccExe.audioMccExe.le_mcc_profile.so -> libIF_testAudioMccExe.audioMccExe.le_mcc_profile.so
libComponent_configDropRead.so -> libComponent_configDropRead.so
libIF_testVoiceCallService.voiceCallTest.le_audio.so -> libIF_testVoiceCallService.voiceCallTest.le_audio.so
libComponent_appCtrl.so -> libComponent_appCtrl.so
libComponent_configTest.so -> libComponent_configTest.so
libIF_le_data_client.so -> libIF_le_data_client.so
libIF_update.updateTool.le_fwupdate.so -> libIF_update.updateTool.le_fwupdate.so
libIF_supervisor.supervisor.le_sup_ctrl.so -> libIF_supervisor.supervisor.le_sup_ctrl.so
libComponent_le_pa_mon.so -> libComponent_le_pa_mon.so
libIF_cm.cm.le_data.so -> libIF_cm.cm.le_data.so
libIF_testRemoteMgmt.remoteMgmtTest.le_cfg.so -> libIF_testRemoteMgmt.remoteMgmtTest.le_cfg.so
libComponent_audioMccExe.so -> libComponent_audioMccExe.so
libComponent_remoteMgmtTest.so -> libComponent_remoteMgmtTest.so
libIF_testPosDaemon.posDaemon.le_gnss.so -> libIF_testPosDaemon.posDaemon.le_gnss.so
libjansson.so.4 -> libjansson.so.4.6.0
libIF_config.config.le_cfgAdmin.so -> libIF_config.config.le_cfgAdmin.so
libIF_testPosDaemon.posDaemon.le_posCtrl.so -> libIF_testPosDaemon.posDaemon.le_posCtrl.so
libComponent_updateTool.so -> libComponent_updateTool.so
libIF_gdbCfg.appConfig.le_cfg.so -> libIF_gdbCfg.appConfig.le_cfg.so
libComponent_voiceCallTest.so -> libComponent_voiceCallTest.so
libComponent_le_pa_gnss.so -> libComponent_le_pa_gnss.so
libComponent_smsDeletion.so -> libComponent_smsDeletion.so
libComponent_configDelete.so -> libComponent_configDelete.so
libIF_appCfgRemove.appConfig.le_cfgAdmin.so -> libIF_appCfgRemove.appConfig.le_cfgAdmin.so
libComponent_smsPduTest.so -> libComponent_smsPduTest.so
libIF_testAudioCfg.cfgTest.le_audio.so -> libIF_testAudioCfg.cfgTest.le_audio.so
libComponent_execInApp.so -> libComponent_execInApp.so
libIF_testModemMdc.mdcTest.le_mdc.so -> libIF_testModemMdc.mdcTest.le_mdc.so
libIF_smackApiTest.smackAPI.le_cfg.so -> libIF_smackApiTest.smackAPI.le_cfg.so
libComponent_watchdog.so -> libComponent_watchdog.so
libComponent_le_pa_audio.so -> libComponent_le_pa_audio.so
libIF_testModemSms.smsTest.le_cfg.so -> libIF_testModemSms.smsTest.le_cfg.so
libIF_watchdog.watchdog.le_cfg.so -> libIF_watchdog.watchdog.le_cfg.so
libComponent_fwupdate.so -> libComponent_fwupdate.so
libIF_testVoiceCallService.voiceCallTest.le_voicecall.so -> libIF_testVoiceCallService.voiceCallTest.le_voicecall.so
libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_audio.so -> libIF_testAudioPlaybackRecExe.audioPlaybackRecExe.le_audio.so
libComponent_smackAPI.so -> libComponent_smackAPI.so
libIF_appCfgInstall.appConfig.le_cfgAdmin.so -> libIF_appCfgInstall.appConfig.le_cfgAdmin.so
libIF_gdbCfg.appConfig.le_cfgAdmin.so -> libIF_gdbCfg.appConfig.le_cfgAdmin.so
libIF_appUserRemove.userAdderRemover.le_cfg.so -> libIF_appUserRemove.userAdderRemover.le_cfg.so
libIF_gdbCfg.gdbCfg.le_cfgAdmin.so -> libIF_gdbCfg.gdbCfg.le_cfgAdmin.so
libIF_appUserAdd.userAdderRemover.le_cfg.so -> libIF_appUserAdd.userAdderRemover.le_cfg.so
libIF_testModemMcc.mccTest.le_mcc_profile.so -> libIF_testModemMcc.mccTest.le_mcc_profile.so
libIF_testModemSms.smsTest.le_sms.so -> libIF_testModemSms.smsTest.le_sms.so
libIF_testRemoteMgmt.remoteMgmtTest.le_remoteMgmt.so -> libIF_testRemoteMgmt.remoteMgmtTest.le_remoteMgmt.so
libComponent_mdcTest.so -> libComponent_mdcTest.so
libComponent_le_pa.so -> libComponent_le_pa.so
libIF_testAudioMccExe.audioMccExe.le_cfg.so -> libIF_testAudioMccExe.audioMccExe.le_cfg.so
libIF_le_sim_client.so -> libIF_le_sim_client.so
/lib:
/usr/lib:
Starting Legato...
Starting the supervisor...
FAILED
any suggestions would be helpful.
