I don’t see problem to printf:
Hi @jyijyi ,
I follow hello1 to modify my test.
I think .adef and .cdef no need to change and I add printf in my first line, then I can’t see the log.
#include <stdio.h>
#include “legato.h”
COMPONENT_INIT
printf(“Test printf\n”);
So I don’t know why I can’t see the log in my window.
Do I miss something?
are you using unsandboxed feature?
can you run the original hello1.rar?
Hi @jyijyi,
I can run hello1, but I follow hello1.rar to modify my .adef ,.cdef and .c , then there is no changed.
my .adef file like below:
sandboxed: false
start: manual
executables:
Larrytest = ( larryComponent )
processes:
envVars:
LE_LOG_LEVEL = DEBUG
run:
( Larrytest )
maxCoreDumpFileBytes: 512K
maxFileBytes: 512K
version: 1.0.1
maxFileSystemBytes: 512K
and my .cdef
sources:
larrytest.c
requires:
device:
[rw] /dev/ttyUSB0 /dev/
and my .c file
#include “legato.h”
#include <stdio.h>
COMPONENT_INIT
printf(“Test printf \n”);
you said “I can run hello1”, then if you run it, can you see the same printf like my screenshot?
Hi @jyijyi ,
Yes, I can, but I copy it to my component, then it doesn’t work, so I thought it was weird.
then you port your code to the hello1.rar line by line and see which line makes the problem.
Hi @jyijyi ,
I found the app status is still running when I updated the app.
I always thought the app would stop automatically when I did the update.
But the result did not turn out as I thought.
I think the app is like daemon, it will keep running as background.
You need to use ctrl+c to stop the app if you use “app runProc” to start the app
Hi @jyijyi ,
Thanks for your help.
Now I know how to print to console.
I need ctrl + c and use “app stop XXX”, then the app will really stop.
Hi @jyijyi ,
Sorry I have other question about input arguments.
I run command like “app runProc larrytest larrytest --exe=larrytest -- hello”
I think “hello” will input to app.
So I add code in my app like:
LE_INFO(“Num of arg %d”, le_arg_NumArgs());
The result is “Aug 2 03:39:17 fx30 user.info Legato: INFO | Larrytest[2515]/larryComponent T=main | larrytest.c _larryComponent_COMPONENT_INIT() 170 | Num of arg 0”
I don’t know how to input argument.
Please help me thanks.
you should use double hyphen sign
you can see this sample code on how to implement le_arg_NumArgs()
you can also see this sample application:
Hi @jyijyi ,
I check .adef and .cdef file is different at “sandboxed: true”
Does it need to sandboxed ?
did you run the sample modemdemo application to verify?
Hi @jyijyi ,
No I didn’t do that because I think it’s too complicated.
Then maybe you should try that
Hi @jyijyi ,
I try to use modemDemo, I update app to device and I don’t know how to use.
I didn’t insert sim card.
you can see here:
