Where can I find a USB driver for the FX Series Modem?
Thanks in advance.
Thanks in advance.
Thank you!
Now I get the following error when installing the driver. Does anyone know what the problem is?
!SESSION 2014-08-05
10:43:43.515 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_67
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Framework arguments:
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.ds 4 0 2014-08-05 10:43:48.234 !MESSAGE !STACK 0
org.osgi.framework.BundleException: The bundle
“org.eclipse.equinox.ds_1.2.1.R36x_v20100803 [1]” could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.util.event; version=“1.0.0”
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1317)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1301)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:319)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!ENTRY com.wavecom.spm.core 2 0 2014-08-05 10:43:59.968 !MESSAGE Unable to find reconciler.dropins bundle
!ENTRY com.wavecom.spm.core 1 0 2014-08-05 10:44:01.359 !MESSAGE Refreshing installed packages
!ENTRY com.wavecom.spm.utils 2 0 2014-08-05 10:44:03.625 !MESSAGE Unable to locate images/arm946.png entry in com.wavecom.spm.model bundle
!ENTRY com.wavecom.spm.utils 2 0 2014-08-05 10:44:03.640 !MESSAGE Unable to locate images/arm7.png entry in com.wavecom.spm.model bundle
!ENTRY com.wavecom.openat.ide.installer 1 0 2014-08-05 10:44:12.265 !MESSAGE Refresh Update site repository:Sierra Wireless Software Suite
!ENTRY com.wavecom.openat.ide.installer 1 0 2014-08-05 10:44:21.437 !MESSAGE Refresh Update site repository:Sierra Wireless Software Suite
!ENTRY com.anwrt.p2.installer 1 0 2014-08-05 10:45:10.421 !MESSAGE Preparing repository for Drivers
!ENTRY com.anwrt.p2.installer 1 0 2014-08-05 10:45:13.609 !MESSAGE Local install Drivers to C:\Program Files\Sierra Wireless\Drivers
!ENTRY com.wavecom.spm.core 1 0 2014-08-05 10:45:13.640 !MESSAGE DirectorApplication Args:[-r, jar:file:/Z:/Temp/sfx1136968.tmp/repositories/Drivers.zip!/, -installIU, com.wavecom.drivers.usb.feature.group/3.8.6.0-201307191237, -destination, C:\Program Files\Sierra Wireless\Drivers, -profile, DriversProfile, -profileProperties, org.eclipse.update.install.features=true, -roaming, -flavor, tooling, -p2.os, win32, -p2.ws, win32, -p2.arch, x86]
!ENTRY com.anwrt.p2.installer 4 0 2014-08-05 10:45:41.156 !MESSAGE Error while installing packages.
!STACK 0
com.wavecom.spm.pluginmanager.InstallException: Error while installing packages.
at
com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:599)
at
com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUIdInProfile(DirectorAppUtil.java:257)
at
com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUInProfile(DirectorAppUtil.java:203)
at
com.wavecom.openat.ide.installer.config.CustomInstallProcess.install(CustomInstallProcess.java:50)
at
com.anwrt.p2.installer.install.InstallableElement.install(InstallableElement.java:441)
at
com.anwrt.p2.installer.install.InstallableElementManager.installElements(InstallableElementManager.java:89)
at
com.anwrt.p2.installer.wizard.AbstractInstallPage$1$1.run(AbstractInstallPage.java:92)
at java.lang.Thread.run(Unknown Source) Caused by: java.lang.Exception: Director application has failed.
Output:
Installing com.wavecom.drivers.usb.feature.group 3.8.6.0-201307191237.
Installation failed.
[Error stream]:
An error occurred while collecting items to be installed
session context was:(profile=DriversProfile,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
Problems downloading artifact:
osgi.bundle,com.wavecom.drivers.usb.win32,3.8.6.0-201307191237.
Caused by: java.io.IOException: There is not enough space on the disk
Application failed, log file location:
Z:\Temp\sfx1136968.tmp\eclipse\configuration\1407231916421.log
at
com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:584)
… 7 more
!ENTRY com.anwrt.p2.installer 4 0 2014-08-05 10:45:41.171
!MESSAGE Unknown issue, end in error
