!SESSION 2011-06-24 18:57:37.409 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_22
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments:
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.ds 4 0 2011-06-24 18:57:44.174
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version=“1.0.0”
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1297)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:309)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!ENTRY com.wavecom.spm.core 2 0 2011-06-24 18:57:56.050
!MESSAGE Unable to find reconciler.dropins bundle
!ENTRY com.wavecom.spm.core 1 0 2011-06-24 18:57:57.940
!MESSAGE Refreshing installed packages
!ENTRY com.wavecom.spm.utils 2 0 2011-06-24 18:58:02.691
!MESSAGE Unable to locate images/arm946.png entry in com.wavecom.spm.model bundle
!ENTRY com.wavecom.spm.utils 2 0 2011-06-24 18:58:02.706
!MESSAGE Unable to locate images/arm7.png entry in com.wavecom.spm.model bundle
!ENTRY com.wavecom.openat.ide.installer 1 0 2011-06-24 18:58:08.941
!MESSAGE Refresh Update site repository:Sierra Wireless Software Suite
!ENTRY org.eclipse.equinox.p2.repository 4 0 2011-06-24 18:58:09.706
!MESSAGE ProvisioningEventBus could not be obtained. Metadata caches may not be cleaned up properly.
!ENTRY com.wavecom.openat.ide.installer 1 0 2011-06-24 18:58:34.473
!ENTRY com.anwrt.p2.installer 1 0 2011-06-24 18:59:01.364
!MESSAGE Preparing repository for Drivers
!ENTRY com.anwrt.p2.installer 1 0 2011-06-24 18:59:03.348
!MESSAGE Local install Drivers to C:\Program Files\Sierra Wireless\Drivers
!ENTRY com.wavecom.spm.core 1 0 2011-06-24 18:59:03.411
!MESSAGE DirectorApplication Args:[-r, jar:file:/C:/Documents and Settings/ocwsadmin/Local Settings/Temp/2/sfx9358796.tmp/repositories/Drivers.zip!/, -installIU, com.wavecom.drivers.usb.feature.group/3.6.3.0-201007091652, -destination, C:\Program Files\Sierra Wireless\Drivers, -profile, DriversProfile, -profileProperties, org.eclipse.update.install.features=true, -roaming, -flavor, tooling, -p2.os, win32, -p2.ws, win32, -p2.arch, x86]
!ENTRY com.anwrt.p2.installer 4 0 2011-06-24 18:59:04.364
!MESSAGE Error while installing packages.
!STACK 0
com.wavecom.spm.pluginmanager.InstallException: Error while installing packages.
at com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:599)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUIdInProfile(DirectorAppUtil.java:257)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUInProfile(DirectorAppUtil.java:203)
at com.wavecom.openat.ide.installer.config.CustomInstallProcess.install(CustomInstallProcess.java:51)
at com.anwrt.p2.installer.install.InstallableElement.install(InstallableElement.java:437)
at com.anwrt.p2.installer.install.InstallableElementManager.installElements(InstallableElementManager.java:77)
at com.anwrt.p2.installer.wizard.AbstractInstallPage$1$1.run(AbstractInstallPage.java:59)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.Exception: Director application has failed.
Output:
Error occurred during initialization of VM
Could not reserve enough space for object heap
[Error stream]:
at com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:584)
... 7 more
