Updated EM7565 to SWI9X50C_01.14.02.00 and now no Carrier aggregation
Just upgraded my EM7565 to the latest generic firmware and carrier aggregation is not working any longer. If I revert back to fw version: 01.07.02.00 GENERIC_002.004_001 it works with everything else being the same. Any ideas on what I might be missing?
Hi @scm
Did you use 9999999_9907259_SWI9X50C_01.14.02.00_00_GENERIC_002.035_000.exe file to update the EM7565 firmware?
AirPrime EM75xx Approved FW Packages
This issue cannot be reproduced after I updated to the latest generic firmware EM7565 SWI9X50C_01.14.02.00.
The log file is attached.log.txt (327 Bytes)
Could you please provide some information about your module and SIM card using below commands?
AT!ENTERCND=“A710”
AT+CPIN?
AT+CGDCONT?
AT!BAND?
AT!GSTATUS?
AT+COPS?
AT+COPS=?
AT!IMPREF?
AT!IMAGE?
AT!CUSTOM?
Thank you for any help/insight. It looks like it should be doing CA but it never actually does and the speed drop from the old firmware does not make sense (nothing else has changed).
AT!CUSTOM?
[/quote]
AT+CPIN?
+CPIN: READY
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“r.ispsn”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“otasn”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
AT!BAND?
Index, Name
00, All bands
AT!GSTATUS?
!GSTATUS:
Current Time: 1988 Temperature: 47
Reset Counter: 1 Mode: ONLINE
LTE band: B41 LTE bw: 15 MHz
LTE Rx chan: 41347 LTE Tx chan: 41347
LTE SCC1 state:INACTIVE LTE SCC1 band: B41
LTE SCC1 bw : 20 MHz LTE SCC1 chan: 41176
LTE SCC2 state:ACTIVE LTE SCC2 band: B41
LTE SCC2 bw : 20 MHz LTE SCC2 chan: 40978
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -83 PCC RxM RSRP: -104
PCC RxD RSSI: -75 PCC RxD RSRP: -94
SCC1 RxM RSSI: -85 SCC1 RxM RSRP: -102
SCC1 RxD RSSI: -79 SCC1 RxD RSRP: -95
SCC2 RxM RSSI: -78 SCC2 RxM RSRP: -105
SCC2 RxD RSSI: -70 SCC2 RxD RSRP: -96
Tx Power: 3 TAC: 4f42 (20290)
RSRQ (dB): -8.8 Cell ID: 0ff62441 (267789377)
SINR (dB): 19.4
AT+COPS?
+COPS: 0,2,“312530”,7
AT+COPS=?
This one just sat there and never responded. Found this in debug log
AT+COPS=?
TIMEOUT ERROR
AT!IMPREF?
!IMPREF:
preferred fw version: 01.14.02.00
preferred config name: GENERIC_002.035_000
preferred subpri index: 000
current fw version: 01.14.02.00
current carrier name: GENERIC
current config name: GENERIC_002.035_000
current subpri index: 000
AT!IMAGE?
FW 1 GOOD 128 0 0 ?? 01.08.04.00?
FW 2 GOOD 1 0 0 ?? 01.07.02.00?
FW 3 GOOD 1 0 0 ?? 01.09.04.00?
FW 4 GOOD 129 0 0 ?? 01.14.02.00?
Max FW images: 4
Active FW image is at slot 4
PRI FF GOOD 0 0 0 002.008_004 01.07.02.00_ATT
PRI FF GOOD 0 0 0 002.015_000 01.09.04.00_DOCOMO
PRI FF GOOD 0 0 0 002.035_000 01.14.02.00_GENERIC
PRI FF GOOD 0 0 0 002.001_000 01.08.04.00_SIERRA
PRI FF GOOD 0 0 0 002.017_000 01.09.04.00_SOFTBANK
PRI FF GOOD 0 0 0 000.001_001 01.08.04.00_SPRINT
PRI FF GOOD 0 0 0 001.000_000 01.07.02.00_TELUS
PRI FF GOOD 0 0 0 002.015_001 01.08.04.00_VERIZON
Max PRI images: 50
AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
SINGLEAPNSWITCH 0x01
QXDMLOGENABLE 0x01
