EM7565: Aggregating B1+B3 does not work as expected
When aggregating B1+B3(+B7) only 3 out of 4 DL streams work.
PCC RxM RSSI:  -59              PCC RxM RSRP:  -80
PCC RxD RSSI:  -53              PCC RxD RSRP:  -74
SCC1 RxM RSSI: -98              SCC1 RxM RSRP: -123
SCC1 RxD RSSI: -57              SCC1 RxD RSRP: -75
SCC1 RxM is dead. This is not due to idle. The EM7565 is the only modem where this issue occurs.
My guess is the modem tries to use a non-existant antenna, as the X16 is actually a 4x4 modem. B1+B3(+B7) is supported according to the specs. We are at least 5 people who are dealing with this issue.
System mode:   LTE              PS state:    Attached
LTE band:      B1               LTE bw:      15 MHz
LTE Rx chan:   372              LTE Tx chan: 18372
LTE SSC1 state:ACTIVE           LTE SSC1 band: B3
LTE SSC1 bw  : Unknown          LTE SSC1 chan: 1875
Please let me know if you need more details.
@Oedenburger
that looks very strange indeed.
this is what I’m getting with B1 PCC and B3 SCC. my setup is 20MHz on both cells.
!GSTATUS:
Current Time: 826 Temperature: 33
Reset Counter: 10 Mode: ONLINE
LTE band: B1 LTE bw: 20 MHz
LTE Rx chan: 300 LTE Tx chan: 18300
LTE SSC1 bw : 20 MHz LTE SSC1 chan: 1575
LTE SSC2 state:NOT ASSIGNED
LTE SSC3 state:NOT ASSIGNED
LTE SSC4 state:NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -61 PCC RxM RSRP: -83
PCC RxD RSSI: -61 PCC RxD RSRP: -82
SCC1 RxM RSSI: -51 SCC1 RxM RSRP: -81
SCC1 RxD RSSI: -51 SCC1 RxD RSRP: -82
Tx Power: -44 TAC: 0001 (1)
RSRQ (dB): -10.2 Cell ID: 01a2d002 (27447298)
SINR (dB): 29.6
Try to swap the main vs DIV antennas to see if the issue follows the antenna.
Also try a different location (home vs office) and switch to a different antenna.
What was your FW version again?
Weird, could you try using the exact same channels? I have noticed all streams work when doing a handover from a different cell or WCDMA/UMTS until the modem enters idle mode again.
Another thing I figured out is that all streams work for the first two seconds when connecting to the cell, then one of them is dead:
First two seconds:
!GSTATUS:
Current Time:  233              Temperature: 32
PCC RxM RSSI:  -57              PCC RxM RSRP:  -81
PCC RxD RSSI:  -51              PCC RxD RSRP:  -74
SCC1 RxM RSSI: -63              SCC1 RxM RSRP: -79
SCC1 RxD RSSI: -58              SCC1 RxD RSRP: -75
After (have a look at Current Time):
!GSTATUS:
Current Time:  235              Temperature: 32
Sorry for forgetting such a major detail. This issue has been present since the very first version that was pre-installed on the module (~ Dec, 2017). Currently I am on:
Model: EM7565
Revision: SWI9X50C_01.07.00.00 33959b jenkins 2018/05/12 15:46:52
MEID: ...
IMEI: ...
IMEI SV: 6
FSN: ...
+GCAP: +CGSM
Thank you for trying to help.
Affected channel bandwidth:
15+15 or 15+10. I cannot test other bandwidths.
The issue is present in whole Austria. We are 5 people from different locations. Swapping Main and Div does not change anything.
I didn’t see the problem with the callbox.
I even matched you channels:
! GSTATUS:
Current Time:  682              Temperature: 32
Reset Counter: 12               Mode:        ONLINE
PCC RxM RSSI:  -52              PCC RxM RSRP:  -82
PCC RxD RSSI:  -52              PCC RxD RSRP:  -82
SCC1 RxM RSSI: -51              SCC1 RxM RSRP: -80
SCC1 RxD RSSI: -51              SCC1 RxD RSRP: -80
Tx Power:      -38              TAC:         0001 (1)
RSRQ (dB):     -9.9             Cell ID:     01a2d001 (27447297)
SINR (dB):     30.0
ati
Model: EM7565
MEID: 35926008000022
ESN: 12801925343, 801D60DF
IMEI: 359260080000224
IMEI SV: 6
FSN: UF726185760404
+GCAP: +CGSM
Do you also see the problem if you start from radio on/off mode? (instead of doing a handover)
At+cfun=0
At+cfun=1
Looks like you are having some issues with B3, maybe noise?
Is it always B3?
I’m wondering if you can replicate the issue without CA.
Try to lock the modem to B3 only and send some data, do you see signal degradation?
With RSRP being -123dBm on the main the modem will not even attach.
at!entercnd="A710"
at!band?
    Index, Name,                        GW Band Mask     L Band Mask 1    TDS Band Mask    L Band Mask 2    L Band Mask 3    L Band Mask 4
    00, All bands                     100600000EC00000 00002100BA0E19DF 0000000000000000 0000000000000002 0000000000000000 0000000000000000
   at!band=?
    Index, Name,                        GW Band Mask     L Band Mask 1    L Band Mask 2    TDS Band Mask    L Band Mask 3    L Band Mask 4
    00, All bands                     100600000EC00000 00002100BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
    01, Europe 3G                     0002000000400000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    02, North America 3G              0000000004800000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    06, Europe                        0002000000400000 00000000000801C5 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    07, North America                 0000000004800000 000001000200185A 0000000000000002 0000000000000000 0000000000000000 0000000000000000
    08, WCDMA ALL                     100600000EC00000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    09, LTE ALL                       0000000000000000 00002100BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
                                                       0000000000000002 - B66
                                                       0000200000000000 - B46
                                                       0000010000000000 - B41
                                                       0000000080000000 - B32
                                                       0000000020000000 - B30
                                                       0000000010000000 - B29
                                                       0000000008000000 - B28
                                                       0000000002000000 - B26
                                                       0000000000080000 - B20
                                                       0000000000040000 - B19
                                                       0000000000020000 - B18
                                                       0000000000001000 - B13
                                                       0000000000000800 - B12
                                                       0000000000000100 - B9
                                                       0000000000000080 - B8
                                                       0000000000000040 - B7
                                                       0000000000000010 - B5
                                                       0000000000000008 - B4
                                                       0000000000000004 - B3
                                                       0000000000000002 - B2
                                                       0000000000000001 - B1
                                      1000000000000000 - B19 (850)
                                      0004000000000000 - B9 (1700)
                                      0002000000000000 - B8  (900)
                                      0000000008000000 - B6  (800)
                                      0000000004000000 - B5  (850)
                                      0000000002000000 - B4 (1700)
                                      0000000000800000 - B2 (1900)
                                      0000000000400000 - B1 (2100)
//// first parameter is the index
//// 2nd - name
//// 3rd GW band mask - you should copy this from the output of at!band? because we are only changing the Lmask
//// L mask  000004 is B3
at!band=10,"LTE B3",100600000EC00000,4
at!band=10
There is nothing in the near of the modem that could intefere. It happens to all of us.
Both bands seem to be affected:
Yes.
At+cfun=0
At+cfun=1
AT!GSTATUS?
!GSTATUS:
Current Time:  16104            Temperature: 38
Reset Counter: 4                Mode:        ONLINE
PCC RxM RSSI:  -97              PCC RxM RSRP:  -75
PCC RxD RSSI:  -56              PCC RxD RSRP:  -84
SCC1 RxM RSSI: -94              SCC1 RxM RSRP: -122
SCC1 RxD RSSI: -48              SCC1 RxD RSRP: -74
Tx Power:      -19              TAC:         ... (...)
RSRQ (dB):     -7.4             Cell ID:     ... (...)
SINR (dB):     23.8
BTW: There is a typo in AT!GSTATUS. SSC should be SCC.
Everything works as expected without CA.
AT!ENTERCND="A710"
AT!BAND=0A,"B1",0,1
AT!BAND=0B,"B3",0,4
### B1 ###
AT!BAND=0A
AT!GSTATUS?
!GSTATUS:
Current Time:  16406            Temperature: 38
LTE SSC1 state:NOT ASSIGNED
PCC RxM RSSI:  -55              PCC RxM RSRP:  -75
PCC RxD RSSI:  -63              PCC RxD RSRP:  -83
Tx Power:      -9               TAC:         ... (...)
RSRQ (dB):     -7.2             Cell ID:     ... (...)
SINR (dB):     20.6
### B3 ###
AT!BAND=0B
AT!GSTATUS?
!GSTATUS:
Current Time:  16474            Temperature: 37
LTE band:      B3               LTE bw:      15 MHz
LTE Rx chan:   1875             LTE Tx chan: 19875
PCC RxM RSSI:  -58              PCC RxM RSRP:  -77
PCC RxD RSSI:  -56              PCC RxD RSRP:  -76
Tx Power:      -6               TAC:         ... (...)
RSRQ (dB):     -7.6             Cell ID:     ... (...)
SINR (dB):     21.4
Were you actually sending data when the modem was locked to B3?
You have mentioned that 5 of you are having the same problem in Austria , are you guys use the same platform?
Any of you have access to a Sierra EM7565 devkit?
Just want to rule out some possible platform noise issue.
Not yesterday, but I did a while ago and now again:
B1:
AT!BAND=0A
AT!GSTATUS?
!GSTATUS:
Current Time:  98504            Temperature: 48
PCC RxM RSSI:  -53              PCC RxM RSRP:  -75
PCC RxD RSSI:  -62              PCC RxD RSRP:  -84
Tx Power:      -12              TAC:         ... (...)
RSRQ (dB):     -7.5             Cell ID:     ... (...)
SINR (dB):     25.0
B3:
AT!BAND=0B
AT!GSTATUS?
!GSTATUS:
Current Time:  98680            Temperature: 42
PCC RxM RSSI:  -49              PCC RxM RSRP:  -78
PCC RxD RSSI:  -46              PCC RxD RSRP:  -75
RSRQ (dB):     -9.4             Cell ID:     ... (...)
SINR (dB):     23.0
It’s evening, so I am not getting the best possible speeds.
No. Some of us are using a Turris Omnia with an embedded M.2 slot. @Sin10 for example.
No.
My Charts are also looking the same, since Jannuary:
–> EM7565 Firmware Problems with CA?
Well the problem is not reproducible on the callbox.
We can’t rule out some NTWK issue.
I setup 2 Cells on the Amari eNB with the same EARFCN (1875,300) and bandwidth (15MHz)
The theoretical max with 2CA MIMO, 15Mhz, 256QAM is ~301Mbps
With iperf I was getting 285Mbps DL transfer ( IP header is not included)
> (enb) cell_gain 1 -10
> (enb) cell
> PLMN=00101 eNB_ID=0x1a2d0
> Cell     TAC   RAT dl_earfcn pci prach_seq dl_gain ul_dis plmn
> 0x001 0x0001   LTE      1875   1       204   -10.0      N 00101
> 0x002 0x0001   LTE       372   2        28     0.0      N 00101
> (enb)
> Amari MAC throughput monitor:
>               ----DL----------------------- --UL------------------------------------------------
> UE_ID  CL RNTI C cqi ri  mcs retx txok brate  snr puc1  mcs rxko rxok brate    turbo phr  pl   ta
>     7 002 0043 2  15  2 27.0   18 7780  290M 16.4 24.2 19.0    0   28 13.9k  0/1.2/2  40  51 -0.1
>     7 002 0043 2  15  2 27.0    0 7800  291M 14.4 24.0 19.3    0   25 11.7k  0/1.0/1  40  51 -0.0
>     7 002 0043 2  15  2 27.0    0 7800  291M 17.2 23.7 19.4    0   25 11.3k  0/1.2/2  40  51  0.0
>     7 002 0043 2  15  2 27.0    0 7800  291M 16.6 23.4 19.4    0   25 11.2k  0/1.0/2  40  52  0.0
>     7 002 0043 2  15  2 27.0    0 7800  291M 13.6 24.0 19.6    0   25 11.2k  0/1.0/2  40  52  0.0
>     7 002 0043 2  15  2 26.9   50 7746  285M 15.8 24.2 19.6    0   28 12.4k  0/1.0/1  40  52  0.0
>     7 002 0043 2  15  2 27.0   10 7788  289M 17.0 23.6 19.7    0   26 11.5k  0/1.0/1  40  52  0.0
>     7 002 0043 2  15  2 27.0    0 6862  256M 16.8 -8.5 19.9    1   25 17.0k  0/1.5/6  40  52 -0.0
>     7 002 0043 2  15  2 27.0    0    8 3.87k 15.6 24.2    -    0    0     0        -  40  52 -0.0
> a/
> !GSTATUS:
> Current Time:  4391             Temperature: 26
> Reset Counter: 2                Mode:        ONLINE
> LTE SSC1 bw  : 15 MHz           LTE SSC1 chan: 1875
> PCC RxM RSSI:  -60              PCC RxM RSRP:  -82
> PCC RxD RSSI:  -60              PCC RxD RSRP:  -81
> SCC1 RxM RSSI: -61              SCC1 RxM RSRP: -90
> SCC1 RxD RSSI: -61              SCC1 RxD RSRP: -89
> SINR (dB):     30.0
> OK
> iperf server (host side iperf, receving end)
> iperf -u -s -i1
> Server listening on UDP port 5001
> Receiving 1470 byte datagrams
> UDP buffer size:  208 KByte (default)
> [  3] local 192.168.2.2 port 5001 connected with 192.168.2.1 port 35784
> [ ID] Interval       Transfer     Bandwidth        Jitter   Lost/Total Datagrams
> [  3]  0.0- 1.0 sec  28.2 MBytes   236 Mbits/sec   0.046 ms 24063/44155 (54%)
> [  3]  1.0- 2.0 sec  34.0 MBytes   285 Mbits/sec   0.036 ms  124/24392 (0.51%)
> [  3]  2.0- 3.0 sec  34.0 MBytes   285 Mbits/sec   0.040 ms  134/24385 (0.55%)
> [  3]  3.0- 4.0 sec  34.0 MBytes   285 Mbits/sec   0.037 ms  120/24385 (0.49%)
> [  3]  4.0- 5.0 sec  34.0 MBytes   285 Mbits/sec   0.043 ms  136/24400 (0.56%)
> [  3]  5.0- 6.0 sec  33.0 MBytes   277 Mbits/sec   0.044 ms  816/24388 (3.3%)
> [  3]  6.0- 7.0 sec  34.0 MBytes   285 Mbits/sec   0.042 ms  129/24389 (0.53%)
> [  3]  7.0- 8.0 sec  32.3 MBytes   271 Mbits/sec   0.095 ms  185/23221 (0.8%)
> [  3]  8.0- 9.0 sec  35.5 MBytes   298 Mbits/sec   0.039 ms  211/25564 (0.83%)
> [  3]  9.0-10.0 sec  34.0 MBytes   285 Mbits/sec   0.042 ms  129/24385 (0.53%)
> [  3] 10.0-11.0 sec  34.0 MBytes   285 Mbits/sec   0.042 ms  134/24388 (0.55%)
> [  3] 11.0-12.0 sec  34.0 MBytes   285 Mbits/sec   0.043 ms  138/24383 (0.57%)
> [  3] 12.0-13.0 sec  34.0 MBytes   285 Mbits/sec   0.039 ms  145/24405 (0.59%)
> [  3] 13.0-14.0 sec  34.0 MBytes   285 Mbits/sec   0.045 ms  124/24384 (0.51%)
> [  3] 14.0-15.0 sec  34.0 MBytes   285 Mbits/sec   0.047 ms  131/24385 (0.54%)
> [  3] 15.0-16.0 sec  34.0 MBytes   285 Mbits/sec   0.037 ms  134/24389 (0.55%)
> [  3] 16.0-17.0 sec  34.0 MBytes   285 Mbits/sec   0.039 ms  139/24400 (0.57%)
> [  3] 17.0-18.0 sec  33.5 MBytes   281 Mbits/sec   0.039 ms  223/24139 (0.92%)
> [  3] 18.0-19.0 sec  32.9 MBytes   276 Mbits/sec   0.039 ms  436/23918 (1.8%)
> [  3] 19.0-20.0 sec  33.2 MBytes   278 Mbits/sec   0.036 ms 1045/24716 (4.2%)
> [  3] 20.0-21.0 sec  34.6 MBytes   290 Mbits/sec   0.041 ms  137/24786 (0.55%)
> [  3] 21.0-22.0 sec  34.0 MBytes   285 Mbits/sec   0.042 ms  165/24389 (0.68%)
> Callbox, client side iperf:
>  iperf -c 192.168.2.2 -u -i1 -b285M -t100
> Client connecting to 192.168.2.2, UDP port 5001
> Sending 1470 byte datagrams
> [  3] local 192.168.2.1 port 35784 connected with 192.168.2.2 port 5001
> [  3]  0.0- 1.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  1.0- 2.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  2.0- 3.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  3.0- 4.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  4.0- 5.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  5.0- 6.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  6.0- 7.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  7.0- 8.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  8.0- 9.0 sec  34.2 MBytes   287 Mbits/sec
> [  3]  9.0-10.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 10.0-11.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 11.0-12.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 12.0-13.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 13.0-14.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 14.0-15.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 15.0-16.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 16.0-17.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 17.0-18.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 18.0-19.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 19.0-20.0 sec  34.2 MBytes   287 Mbits/sec
> [  3] 20.0-21.0 sec  34.2 MBytes   287 Mbits/sec
NTWK? Network?
Why would it be a network issue if the EM7565 is the only (known) device with such an issue? I have never seen this happening on my Huawei B618 or Galaxy S8 (Samsung SoC).
If it matters: They are using ZTE eNodeBs. I still think the modem tries to use a non-existant antenna.
Ok, so it is not happening with other devices.
It is possible, it would be much easier to troubleshoot the issue if I could replicate the problem locally.
There are two things I can still think of:
  • You have (almost) no noise in your testing environment.
  • The Modem does not see your Cell on the non-existing / not connected antenna(s). An RSRP of -122 is very bad but still usable to a certain degree.
I have a good news and a bad news…
The good news is that FW team fixed the bug. Your hunch was correct the issue was related to antenna switching.
This only affects CA 1+3, 2+4 and 2+66.
Unfortunately we are not planning to release a new EM7565 FW anytime soon. They next scheduled release is around June 2019.
James
Hey, thanks for the reply and taking the issue seriously.
June 2019 is a very late release for the new firmware. (8 Month !)
We’re struggeling with this issue since almost a year, it would be a pleasure to finally get our modules in a properly working state.
Is there a chance we can get our hands on a inofficial build maybe?
idontreally
I agree. You can’t tell us you fixed the issue and not release a fixed firmware for the next 8 months. This is also security-wise a very bad decision. I mean, seriously, come on, you can’t be serious on this.
We are dealing with this problem since December, 17 and have been ignored for a very long time and now we should wait for another 8 months?
I would have to replace a lot of hardware just because you do not want to release an update.
Please think about it, and also do not forget, 1+3+8 is officially supported and affected as well.
The latest “Product technical specification” PDF also lists B1+B3 as officially supported. You really want to delay this update for another 8 months?
You updated the CA table in Oct. 2018 where you already knew B1+B3 doesn’t work properly…
Are you serious, Sierra?
Just update the firmware now, there is no reason to delay this further. People are paying customers for almost 2 years now, without a proper working device.
If it’s an easy fix, then a fast firmware release would be no problem I guess. If it’s harder to fix - so be it - but at least tell us.
Nope, they are ignoring us again. Great customer service. I thought they are finally taking our problems serious, but apparently not… Sad … That’s almost ZTE level customer service.
Time for another entry on my “Do Not Buy” list. I am done with this.
After reading this, I spit out my drink. Are you kidding me? I’m in the US and bought this modem SPECIFICALLY to be able to leverage 2+66 and yet I run into this issue constantly. What in the world would drive you to tell us that you found the fix and then tell us you’re going to sit on it for 8 months? This has to be a joke…
