Unresolved symbol
Hi.
On TMT I get:
RTK 1 Except RTK …190 19 25
ADS Bckt -> Unresolved symbol : 0x00044DB3
How can I know wich symbol in my code is 0x00044DB3 ?
Where can I get more info. on Backtraces’ messages ?
arghh… someone ??
What is the meaning of error “Except RTK …190”?
The error “Except RTK …190” stands for Stack Overflow. This error occurs, when the Open AT® application uses local variables which exceed the size of custom stack defined in the Open AT® application.
the first parameter 190, which is an exception identifier, indicates that it is stack overflow. The third parameter 25 (Task Identifier) is the Open AT® application’s task identifier. This is pointing to one of the many tasks declared in the Open AT application. This indicates that the exception is generated from the Open AT® application!
good luck
and see this:
What is the reason for getting Back Trace RTK 190?
The Back Trace RTK 190 signifies that custom stack size used is not big enough (there’s a stack overflow). In this case it is recommended to increase the stack size.
