Hi all,
After installing Development Studio plugins into Eclipse in Linux Mint 15 without any problem. In orther to be able to create a new library project I’m trying to install Open AT Framework pacakge 2.51, to pass the “Hardware Configuration” set, but I always receive “Impossible to install selected packages” with Reson: “Impossible to install some packages” and no more detailed information.
After looking into error log file, I’ve following trace:
com.wavecom.spm.pluginmanager.InstallException: Error while installing packages.
at com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:733)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUIdInProfile(DirectorAppUtil.java:302)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUInProfile(DirectorAppUtil.java:250)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installSPMPackInTempProfile(DirectorAppUtil.java:224)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.access$0(DirectorAppUtil.java:212)
at com.wavecom.spm.pluginmanager.DirectorAppUtil$SpmPackInstallRunnable.run(DirectorAppUtil.java:66)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.io.IOException: Unable to determine the product launcher
at com.wavecom.spm.pluginmanager.DirectorAppUtil.getLauncher(DirectorAppUtil.java:811)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.invokeDirectorApplication(DirectorAppUtil.java:672)
I’ve tried several configurations of jdk versions (Sun: 1.6.0_45, 1.7.0_46 and openjdk 1.7.0_25) but nothing works.
Any possible hint about this.
Thank you in advance.
