subj.
!SESSION 2010-03-22 11:46:37.109 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Framework arguments:
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.wavecom.spm.core 2 0 2010-03-22 11:47:10.562
!MESSAGE Unable to find reconciler.dropins bundle
!ENTRY com.wavecom.spm.core 1 0 2010-03-22 11:47:10.765
!MESSAGE Refreshing installed packages
!ENTRY com.wavecom.spm.utils 2 0 2010-03-22 11:47:10.921
!MESSAGE Unable to locate images/arm946.png entry in com.wavecom.spm.model bundle
!MESSAGE Unable to locate images/arm7.png entry in com.wavecom.spm.model bundle
!ENTRY com.wavecom.openat.ide.installer 1 0 2010-03-22 11:47:10.921
!MESSAGE Checking local repo path: C:\Temp\sfx731890.tmp\repositories\Expresso
!MESSAGE Checking local repo path: C:\Temp\sfx731890.tmp\repositories\SPMPackages
!MESSAGE Checking local repo path: C:\Temp\sfx731890.tmp\repositories\M2MStudio
!MESSAGE Checking local repo path: C:\Temp\sfx731890.tmp\repositories\Drivers
!ENTRY com.wavecom.openat.ide.installer 1 0 2010-03-22 11:47:33.312
!MESSAGE Refresh Update site repository:Open AT Software Suite
!ENTRY org.eclipse.equinox.p2.repository 4 0 2010-03-22 11:47:33.312
!MESSAGE ProvisioningEventBus could not be obtained. Metadata caches may not be cleaned up properly.
!ENTRY com.anwrt.p2.installer 4 0 2010-03-22 11:47:33.343
!MESSAGE No repository found at file:/C:/Temp/sfx731890.tmp/repositories/M2MStudio.
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at file:/C:/Temp/sfx731890.tmp/repositories/M2MStudio.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:380)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:641)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at com.anwrt.p2.installer.install.InstallableElement.retreiveInstUnit(InstallableElement.java:236)
at com.anwrt.p2.installer.install.InstallableElement.getAllInstUnits(InstallableElement.java:157)
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.addMainTools(SetupRepositoryImpl.java:136)
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.refreshSubContainers(SetupRepositoryImpl.java:78)
at com.wavecom.openat.ide.installer.pages.softwares.SoftwareSelection$7.run(SoftwareSelection.java:264)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-03-22 11:47:33.343
!ENTRY com.anwrt.p2.installer 4 0 2010-03-22 11:47:38.906
!MESSAGE No repository found at file:/C:/Temp/sfx731890.tmp/repositories/Expresso.
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at file:/C:/Temp/sfx731890.tmp/repositories/Expresso.
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.addMainTools(SetupRepositoryImpl.java:160)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-03-22 11:47:38.906
!ENTRY com.anwrt.p2.installer 4 0 2010-03-22 11:47:43.406
!MESSAGE No repository found at file:/C:/Temp/sfx731890.tmp/repositories/SPMPackages.
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at file:/C:/Temp/sfx731890.tmp/repositories/SPMPackages.
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.addSPMPackages(SetupRepositoryImpl.java:186)
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.refreshSubContainers(SetupRepositoryImpl.java:81)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-03-22 11:47:43.406
!ENTRY com.anwrt.p2.installer 4 0 2010-03-22 11:47:45.203
!MESSAGE No repository found at file:/C:/Temp/sfx731890.tmp/repositories/Drivers.
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at file:/C:/Temp/sfx731890.tmp/repositories/Drivers.
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.addDrivers(SetupRepositoryImpl.java:97)
at com.wavecom.openat.ide.installer.setuppkg.impl.SetupRepositoryImpl.refreshSubContainers(SetupRepositoryImpl.java:84)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-03-22 11:47:45.203
!ENTRY com.anwrt.p2.installer 1 0 2010-03-22 11:48:59.359
!MESSAGE Remote install M2M Studio to C:\Program Files\Sierra Wireless\m2mstudio
!ENTRY com.wavecom.spm.core 1 0 2010-03-22 11:48:59.390
!MESSAGE DirectorApplication Args:[-r, http://www.wavecom.com/eclipseUpdates/m2mstudioProduct, -installIU, com.wavecom.openat.ide.product/1.1.1.200911160856-R3160, -destination, C:\Program Files\Sierra Wireless\m2mstudio, -profile, M2StudioProfile, -profileProperties, org.eclipse.update.install.features=true, -roaming, -flavor, tooling]
!ENTRY org.eclipse.ecf.provider.filetransfer 4 1001 2010-03-22 11:57:40.312
!MESSAGE Transfer Exception
!STACK 0
java.io.InterruptedIOException: Timeout while reading input stream
at org.eclipse.ecf.provider.filetransfer.util.PollingInputStream.read(PollingInputStream.java:159)
at java.io.FilterInputStream.read(Unknown Source)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer$1.performFileTransfer(AbstractRetrieveFileTransfer.java:140)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:73)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.ecf.provider.filetransfer 4 1001 2010-03-22 12:04:10.406
!STACK 0
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-03-22 12:04:12.171
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-03-22 12:04:12.171
!MESSAGE session context was:(profile=M2StudioProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.phases.Collect, operand=, action=).
!SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2010-03-22 12:04:12.171
!MESSAGE Unable to read repository at http://www.wavecom.com/eclipseUpdates/m2mstudioProduct/binary/com.wavecom.openat.ide.jre_root.win32.win32.x86_1.6.0.
!STACK 0
!MESSAGE Unable to read repository at http://www.wavecom.com/eclipseUpdates/m2mstudioProduct/plugins/org.eclipse.platform.doc.isv_3.5.0.v20090611.jar.
!STACK 0
!ENTRY com.anwrt.p2.installer 4 0 2010-03-22 12:04:12.171
!MESSAGE Impossible to install IUs in the temp profile
!STACK 0
com.wavecom.spm.pluginmanager.InstallException: Impossible to install IUs in the temp profile
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUIdInProfile(DirectorAppUtil.java:242)
at com.wavecom.spm.pluginmanager.DirectorAppUtil.installIUInProfile(DirectorAppUtil.java:182)
at com.anwrt.p2.installer.install.DefaultInstallProcess.install(DefaultInstallProcess.java:17)
at com.wavecom.openat.ide.installer.config.CustomInstallProcess.install(CustomInstallProcess.java:47)
at com.anwrt.p2.installer.install.InstallableElement.install(InstallableElement.java:331)
at com.anwrt.p2.installer.install.InstallableElementManager.installElements(InstallableElementManager.java:77)
at com.anwrt.p2.installer.wizard.AbstractInstallPage$1$1.run(AbstractInstallPage.java:59)
at java.lang.Thread.run(Unknown Source)
and your link is what i need).
