i have to make a conection through uart1_main with dev kit airprime. Due to, i make a dial up on windows 10 setting the modem via com 5 set by the pc.
i am not able to connect via uart1_main to pc, so there are some default configuration or some configuration that i have to set for this?
I try to connect the modem dialing up but i encountered error 639 hardware error.
By the way when i connect uart with teraterm i can put at command without problems.
somebody can help?
