Trying DOTA example in SDK 4.22a
I just installed SDK v4.22a and development toolkit v2.9.6
I’m using a Q2687.
I ran the hello world example, no troubles at all in RTE mode.
I then used the project wizard to create a project based off of sample DOTA using the linked plug-in WIP. I ran that in RTE mode, entered my bearer info using the AT+APNPARAMS. connected to bearer ok. I then sent in the SMS for FTP instruction and it parsed that OK. But when the FTP actually started, with dots printing in the terminal emulator, i got a crash in \mingw\out\kernel.exe File:afxtemp.h Line:666
I then hit “ignore” button, but the pause probably caused the ftp server to time out. here is my trace from TMT:
Trace CUS4 1 Embedded Application : Main -858993460
Trace CUS4 1 DOTA_AnDEventHandler: Event 0, Progress 0
Trace CUS4 1 SIM Event = 1
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 8
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 16
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 24
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 33
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 41
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 49
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 57
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 66
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 74
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 82
Trace CUS4 1 DOTA_AnDEventHandler: Event 1, Progress 90
Trace CUS4 1 DOTA_AnDEventHandler: Event 2, Progress 100
Trace ATI 1 Unable to find the string of the remote trace in the file (ID = 8842)
Trace DEV 1 Unable to find the string of the remote trace in the file (ID = 12654)
Trace CUS4 1 SIM Event = 5
Trace CUS4 1 ADL_SIM_STATE_FULL_INIT
Trace CUS4 1 [GPRS]: initialized.
Trace CUS4 1 [GSM]: initialized.
Trace CUS4 1 [UART1]: initialized.
Trace CUS4 1 [UART2]: initialized.
Trace CUS4 1 []: initialized.
Trace CUS4 1 [GPRS]: open: -> DISCONNECTED
Trace CUS4 1 wip_bearerOpen: 0
Trace CUS4 1 wip_bearerSetOpts: 0
Trace CUS4 1 [GPRS]: start: -> CONNECTING
Trace CUS4 1 wip_bearerStart: -27
Trace CUS4 1 [GPRS]: GPRS EVENT SETUP OK (cid=1): GPRS activate
Trace CUS4 1 [GPRS]: GPRS EVENT: 27 (cid=1)
Trace RLU 1 Unable to find the string of the remote trace in the file (ID = 528)
Trace CUS4 1 [GPRS]: GPRS EVENT ACTIVATE OK (cid=1): FCM open
Trace CUS4 1 [GPRS]: FCM subscribe: 0
Trace CUS4 1 [GPRS]: FCM EVENT FLOW OPENNED: -> CONNECTED
Trace CUS4 1 DOTA_GprsEvHandler: event 2
Trace CUS4 1 WIP_BEV_IP_CONNECTED
Trace L3RR 1 Unable to find the string of the remote trace in the file (ID = 4867)
Trace MMT 1 Unable to find the string of the remote trace in the file (ID = 11368)
Trace CUS4 1 FTP filename
Trace CUS4 1 gcc_DOTA_256KB.wpb.dwl
Trace CUS4 1 path
Trace CUS4 1 ./
Trace CUS4 1 FTP Server
Trace CUS4 1 66.252.141.3
Trace CUS4 1 FTP Server UN
Trace CUS4 1 anonymous
Trace CUS4 1 FTP Server PW
Trace CUS4 1 ass@hat.com
Trace CUS4 1 wip_FTPCreateOpts: 4886c8
Trace CUS4 1 FileName=
Trace CUS4 1 .//gcc_DOTA_256KB.wpb.dwl
Trace CUS4 1 [FTP=>] “220 Please visit sourceforge.net/projects/filezilla/
Trace CUS4 1 [FTP<=] USER anonymous
Trace CUS4 1 [FTP=>] “331 Password required for anonymous”
Trace CUS4 1 [FTP<=] PASS ass@hat.com
Trace CUS4 1 [FTP=>] “230 Logged on”
Trace CUS4 1 [FTP<=] TYPE I
Trace CUS4 1 [FTP=>] “200 Type set to I”
Trace CUS4 1 DOTA_FtpSessionHandler: Event: 2
Trace CUS4 1 WIP_CEV_OPEN
Trace CUS4 1 [FTP<=] PASV
Trace CUS4 1 [FTP=>] “227 Entering Passive Mode (66,252,141,3,10,27)”
Trace CUS4 1 [FTP<=] RETR .//gcc_DOTA_256KB.wpb.dwl
Trace CUS4 1 DOTA_FTPFileDataHandler Event = 2
Trace CUS4 1 DOTA_FTPFileDataHandler Event = 6
Trace CUS4 1 [FTP=>] “150 Connection accepted”
Trace CUS4 1 DOTA_FTPFileDataHandler Event = 5
Trace CUS4 1 Length Read = 536
Trace SNDCP 1 Unable to find the string of the remote trace in the file (ID = 1115)
Trace CUS4 1 [FTP=>] “426 Connection timed out, aborting transfer”
Trace CUS4 1 DOTA_FtpSessionHandler: Event: 1
Trace CUS4 1 WIP_CEV_ERROR 426
Trace CUS4 1 DOTA_FTPFileDataHandler Event = 1
Trace CUS4 1 FTP WIP_CEV_ERROR
Trace CUS4 1 [FTP=>] “421 Connection timed out.”
Trace CUS4 1 ERRLOG ftp_evh.c:126: Unexpected reply arriving from server
Trace CUS4 1 DOTA_FtpSessionHandler: Event: 3
Trace CUS4 1 WIP_CEV_PEER_CLOSE
Trace CUS4 1 [WIP] closing TCPCLIENT 0x4789c8
Trace CUS4 1 ERRLOG ch_channel.c:148: returned WIP_CERR_CSTATE
I have not yet tried to run in in target mode, will try.
but the RTE kernel died right when the FTP transfer started.
There have been limitations meaning that WIP doesn’t work with remote mode - are you sure these are supposed to be fixed in this version?
The thing to remember is that all the data is still coming through the actual wireless CPU - therefore it has to be transferred across the serial link to the PC, along with all the other event data, etc.
I gave up trying to use remote mode with large data transfers like this because I found that the link just couldn’t keep up! :frowning:
See: wavecom.com/modules/movie/sc … ght=remote
That was CSD and XMODEM, but I guess the same issues would apply - even assuming that WIP does now work properly with Remote Mode…
