Hello.
I have to implement the Special Telit at commands for sending data through tcp socket.
I have a running unchangeable Controller that uses a telit modem for sending data.
The commands are similar to the at wip commands but not equal.
AT+CPIN? //Check Pin Status
AT+CPIN="xxxx" //Set Pin Code
AT+CREG? //Get Network Status
AT#SELINT=2 //Select Interface Style
AT+CGDCONT=1,"IP","ibox.tim.it","0.0.0.0",0,0 //Set Context ibox.tim.it
AT#SCFG=1, 1,300, 40,200,5 //Config Socket
AT#SGACT=1,1 //GPRS on
AT#SD=1, 0,80,80.x.x.x,0 //Activate Connection
//Data exchange
POST /sensor.php HTTP/1.0
Host: x.x.x.x
Content-type: application/x-www-form-urlencoded
Content-length: 328
data=<sd></sd>
+++ //End of Data
AT#SH=1 //Socket Shutdown
AT#SGACT=1,0 //GPRS off
For Details see telit.com/module/infopool/do … hp?id=1603
It would be great to get some information regarding best practice to implement this at commands. thank you
