Is it possible to use the Open AT Project Wizard with Visual C++ 8.0 as the associated IDE? As of now it doesn’t recognize Version 8.0. Is there a way to around this?
Scott
Scott
I forgot to mention:
I am using Open AT IDE Version 1.02.03
Project Wizard Version 2.0.3.3
WMToolkit DLL Version 2.0.2.1
Does this help:
Yes it does! Either this forum search tool isn’t very robust or I am an idiot and missed that post. Regardless, thank you for the reply!
I noticed in your response in that thread, you said:
Could you explain that a bit further please? Should I create a project with no associated IDE and then do what you explained?
awneil:
I have tried to follow your instructions, but get a “.vcs: No such file or directory” error. Am I missing something?
Try with .scs instead…
List the files and see what file it is manually if you want…
Yes - there was a typo in my original post. ![]()
“vcs” should have been “scs”
The clue is in the name of the command: wm_[color=red]scs2[color=blue]vcproj - it converts a [color=red].scs file to a [color=blue]vcproj
