Standard AT command reference for WP76xx
I have the document for the proprietary commands but I can’t find the standard AT command reference. I have been provided with a modem to integrate into an existing product (upgrade from another brand of modem) so I don’t have the SDK. Where can I download the standard AT command reference please?
https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
Thanks mlw but that it the proprietary commands document that I already have.
I am looking for all the standard commands such as AT+CREG and AT+CSQ.
Hi @lesgrant
Standard 3GPP AT commands support is listed in section 15 of the AT command guide: Supported GSM/WCDMA AT Commands
For detailed description of those commands you need to refer to the various public standard mentioned at the beginning of section 15:
  • ITU recommendation v.250
  • 3GPP TS 27.005 and TS 27.007
Thanks bbo. I was hoping that Sierra Wireless would have a document that covered all the AT commands as supported by a particular family of modems. Anyway, I have located and downloaded the following documents. I hope they are the correct (latest) versions…
https://www.itu.int/rec/dologin_pub.asp?lang=e&id=T-REC-V.250-200307-I!!PDF-E&type=items
https://www.itu.int/rec/dologin_pub.asp?lang=e&id=T-REC-V.250-200106-I!Sup1!PDF-E&type=items
https://www.3gpp.org/ftp/Specs/archive/27_series/27.005/27005-f00.zip
https://www.3gpp.org/ftp/Specs/archive/27_series/27.007/27007-g00.zip
Thanks for your help.
