I am trying to run the example application of the SSL client.
when i try to run the code, I get:
“[SSL][ERROR] Can’t create SSL channel : (reason) SSL Library closed”
what could be the reason for that message?
Itay
Itay
I am experiencing the same problem and I am wondering if you (or others) have resolved it.
Thank you,
Jeremy.
The OpenlSSL library requires licensing and so is locked by default. Contact your distributor for an unlocking key - they will require your IMEI.
