SSH Linux Commands
Hi @e.kasap,
The AT command you’ve referenced doesn’t perform a factory reset, it will enable or disable the FX30 factory reset. If you are running the stock WP7702 firmware, this command will not function. You must be running FX30 firmware.
I suspect your device will need to be hard booted into boot and hold mode in order to install firmware. Please try the procedure here:
BR,
Chris
