Hi guys,
I’m working with two SL8082 modules, but I don’know why, one just don’t answer me anymore if I try to connect to the AT command port. I’m using HTerm to connect to it, and I noticed that I don’t receive a CTS from the module that doesn’t work. Although I can connect to it through the watcher. Do you guys have any idea of what is happening or what should I do?
Coming back to the working module I need to connecto to a web server send\get some data and close the connection, I just wonder if the PAD commands do something similar to what we do when we use WIPsoft for the same purpose. If no, is it possible to install WIPsoft on SL8082? I’ve tried without success.
Thanks in advance.
