SIM Carrier Switch on XR60 Configuration
I have an XR60 router and use a single roaming sim. I want to set up a configuration in the router so that I can automatically switch to a better carrier if the rules I create ask for this. At the moment I’m doing this purely on RSSI, but ideally i’d also like it to consider RSRQ and RSRP. Can I do this? I see on the dashboard that I can see the metrics for the RQ and RP, but no where that I can configure them.
Hi @aelcock,
Welcome to our community!
Based on the description, I understand that you have a roaming SIM that can switch between multiple carriers. And now, you want to configure XR60 router so that it can automatically switch to a better carrier if the RSRQ and RSRP rules are met, is that right?
If that’s what you mean, then the XR60 router doesn’t support that feature. The router supports Auto SIM Switching, where you can configure the conditions which the router automatically switches SIM cards.
Refer to the following link: SIM Slot Management and Configuring SIM Failover - XR60-5.3 - Sierra Wireless
