I was using M1306B before, and changed into Fastrack supreme10 now; I keep using the old M1306B cable, but it doesn’t work for the Fastrack supreme10? Is there anyone get the same problem??
Please advise.
thanks
Melvin
Please advise.
thanks
Melvin
I use exactly the same cables with M1306B and Supreme with no problem - so there must be something wrong with your cable and/or your application and/or your setup.
What cable are you using?
Have you chedcked the “Delta between M1306B and Supreme” document to verify that you aren’t relying upon something that’s changed…?
Solved thanks…I think it may due to the handshaking problem, since the old cable, do not connect with those pins for handshaking but Fastrack supreme required to have it at the beginning.
thanks
