RX55 Programming Manual
Does anyone have experience with setting up the RX55 serial port? I cannot find any documentation online and when you try yo use the Source it lists nothing and serial is greyed out. There is also no offline documentation available that I can find like with the RV55 OS, etc.
The serial settings menu in the RX55 seem incorrect
Hi @mrb188,
You can refer to Serial port section on page 23 of AirLink RX55 Hardware User Guide at the following link: https://source.sierrawireless.com/resources/airlink/hardware_reference_docs/airlink_rx55_userguide/#sthash.5iWfukuf.dpbs
This documentation doesn’t offer any “programming” information, only how to connect a serial cable and the pinout. As stated in the original post I have TCP/UDP settings showing up under the serial connection properties tab and no explanation of settings choices or what they do…
Hi @mrb188,
I also searched the source page and didn’t find specific documentation that mentions the RX55’s Serial port. I think it’s better is send an email to technical support at support@sierrawireless.com for more detailed information.
