Hi there
RV5X with 4.17.1 and with SNMP tester, I can’t get SNMPv3 SHA AES combo to work. Below does work:
V2
V3 SHA DES
I’m using Debug your SNMP configuration with SNMP Tester and able to pull OIDs when testing.
Any ideas.
Hi there
V2
V3 SHA DES
Any ideas.
Hi @ahong,
“I can’t get SNMPv3 SHA AES combo to work. Below does work:
V2
V3 SHA DES”
→ I’m still not clear on what you mean. Do you mean that you can’t get SNMPv3 SHA AES combo to work and it only works with V2, is that correct? If not, please describe in more detail.
SNMPv3 is setup for “Read Only SNMP User.” FYI - I am not using Read/Write SNMP User or TRAP server User which is default with “disable” and/or “none”
So with Read Only SNMP user, it does work when I use
Authentication Type = SHA
Privacy Type = DES
It does NOT work when I change the Auth type = SHA with Privacy Type = AES
Hi @ahong,
Could you please share the template file, screenshot of the configuration on the SNMP tool and what the error message is?
