RV50x high data usage after SIM change
I had to take over the gateways that are used for road signs. They changed the SIM cards from 3G to Verizon LTE, and since then, each one receives a substantial amount of data. Not much data is being sent out. The host on the gateway does not show any traffic other than 6 packets just after reboot, so maybe the gateway itself is generating the traffic? There is only 1 host and it’s connected to the serial interface. I have it secure now as it wasn’t that secure when it got dumped in my lap. All the remote management and ALMS features are turned off. The first thing I did was upgrade from 4.9.4 to 4.9.13. I know that the gateway drops unsolicited traffic by default, so why is the gateway receiving so much data per day. I think the average now for the month for the gateway is 80GB, but we do not have unlimited. Verizon isn’t much help. Any help would be greatly appreciated.
Hi @todd_bumbarger,
  • Does the increase in receiving data happen before upgrading when the gw is in 4.9.4?
  • Did the traffic display in log file?
  • Do you know the exact bytes the gw receive per day
  • The device may also be communicating to the network for the other things like NTP…
  • Did you try any reboot the gw. Is it helpful?
Yeah the increase was there before upgrading to 4.9.13. As for the log file, I don’t see anything in it regarding traffic. I plan on doing IP logging today to at least see traffic coming in on the WAN interface. I have factory reset with core settings kept and the traffic has slowed substantially it seems, but I have yet to check this today. Either way it’s receiving I would say 1-2 KB per minute after factory reset as opposed to out of control data use. Whenever it seems stable and not using much data after factory reset, I try to start securing it again, and it just starts going out of control with data usage again. We only have 10 MB plans, so even 1-2 KB per minute equates to over 1.5 to 3 MB per day roughly.
Once I determine the traffic source, I will update post and hopefully have resolved the issue. Thanks
Please share any concerns you have. If my response answered your question please click the Solutions under my response. This ensures others can benefit from the topic. Thanks in advance for your help with this!
