WP76xx module is able output 32kHz(clock) signal, but it is a bit different(offset -103ppm) with general RTC clock(32k768Hz).
You still possible to have RTC, if your system accept this frequency.
On another hand, you could consider ESPON RX8010SJ.
It can operate below 1V6(still keep counter content in 1V0) and has build crystal(no matching issue).
Thanks for reply. We have decided to go with external I2C RTC with super capacitor backup but we are still in schematic drawing (perhaps we can change decision based on your further details). Can you give more details about WP76xx 32kHz output:
Which pin is used for that?
This signal is generated when WP76xx is powered off? Which pin is used for battery backup?
Are you saying that accuracy is ±100ppm or only offset? If you are talking about offset what is accuracy?
What is power consumption of such an integrated RTC (so we can calculate battery backup capacity)?
[LChing] The 32k signal output pin is LGA #23.
[LChing] This signal is divided from system clock and WP76xx haven’t battery backup function. So clock signal will be stopped when module power off.
[LChing] Sorry for my wrong presentation in before. The 32k signal has a offset(~-103ppm) to general RTC signal(32k768Hz). It is frequency offset issue and not accuracy(stability) issue.
[LChing] 1) 320nA(3V, no I2C clock=0Hz, nIRQ1,2=off), 2) 900nA(3V, no I2C clock=0Hz, nIRQ2=1024Hz ON)
NOTE, the current leakage & function of I2C bus when module power off.
To compare another RTC chip, the consumption is higher than it and need to buy & SMT processing for a crystal. Also the manufacturer take the responsibility of accuracy issue(to reduce risk of SMT or components) .
Now a day, you could get a RTC information such from GPS or internet.
Mean you can have real time information when connected world like your smart phone.
