Hello everybody,
i have a really simple question but i couldn’t find a solution…
How can I reset the modem to factory default settings?
I’ve accidentally sent “AT!MAPUART=1” to the modem, but in my board UART is not connected, i use only USB for communicate.
Suggestions?
Alepiro
Hiya,
Which modem are you using?
You might have to use DWLWin to reflash the firmware and delete any configuration.
ciao, Dave
Hi Dave!
I’m using an SL8092 module; if yours is the only solution and there is no way to reset the module, i think i will connect uart for remap usb port.
Thank you
Alepiro
Hiya,
I haven’t used the SL8092 module, so I can’t give you any advice on how to get it into boot mode which is required to use DWLWin.
You might have to talk to your FAE.
ciao, Dave
