Hi there,
I am currently trying to understand the rollback behaviours on a mangoh yellow. First of all, I realized it is necessary to mark the deployed applications as good (as in legato status) to avoid rollbacks of the applications in case of for instance brown outs.
But now I have a setup, where in a brown out the the legato apps will survive, but the content of the filesystem is presumably getting lost, specifically files in /etc. I tried to use AT!NVBACKUP to mark it as a valid image and executed, for testing purposes, AT!RMARESET=3 after deleting on of the files to check if the files would magically reappear. Unfortunately, they do not.
Hence, I am now a little bit confused. Will AT!NVBACKUP only ensure that the apps will get recovered in a reset, or should this also cover the filesystem? And, if if doesn’t, how can I ensure that the content of the filesystem gets persisted, so that in case of a recovery they will be available again?
I found something new, the command AT!NVRESTORE. Of course I tried it, but now I am stuck in a state where the virtual network device doesn’t appear anymore. If I remember it correctly one of the devices should get renamed and turned into a network device?
[ 3167.826413] usb 3-2.1: new high-speed USB device number 29 using xhci_hcd
[ 3167.931934] usb 3-2.1: config 1 has an invalid interface number: 8 but max is 3
[ 3167.931942] usb 3-2.1: config 1 has no interface number 1
[ 3167.939754] usb 3-2.1: New USB device found, idVendor=1199, idProduct=68c0, bcdDevice= 3.18
[ 3167.939765] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3167.939769] usb 3-2.1: Product: WP7608
[ 3167.939771] usb 3-2.1: Manufacturer: Sierra Wireless, Incorporated
[ 3168.054857] qcserial 3-2.1:1.0: Qualcomm USB modem converter detected
[ 3168.055144] usb 3-2.1: Qualcomm USB modem converter now attached to ttyUSB1
[ 3168.080229] qcserial 3-2.1:1.2: Qualcomm USB modem converter detected
[ 3168.080472] usb 3-2.1: Qualcomm USB modem converter now attached to ttyUSB2
[ 3168.112112] qcserial 3-2.1:1.3: Qualcomm USB modem converter detected
[ 3168.112360] usb 3-2.1: Qualcomm USB modem converter now attached to ttyUSB3
[ 3168.144680] qmi_wwan 3-2.1:1.8: cdc-wdm1: USB WDM device
[ 3168.153722] qmi_wwan 3-2.1:1.8 wwan0: register 'qmi_wwan' at usb-0000:05:00.3-2.1, WWAN/QMI device, be:28:bd:51:5a:5a
I can still flash the board via swiflash, but I am unable to get the SSH connection up and running. Does anybody have an idea how this could have happened and how I can solve it again?
at!entercnd="A710"
at!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0000010D (diag,nmea,modem,rmnet0)
at!usbcomp=1,1,8010D
at!usbcomp?
Config Index: 1
Interface bitmask: 0008010D (diag,nmea,modem,rmnet0,ecm)
[ 9009.418408] usb 3-2.4.1: new high-speed USB device number 31 using xhci_hcd
[ 9009.523765] usb 3-2.4.1: config 1 has an invalid interface number: 8 but max is 5
[ 9009.523775] usb 3-2.4.1: config 1 has an invalid interface number: 19 but max is 5
[ 9009.523779] usb 3-2.4.1: config 1 has an invalid interface number: 20 but max is 5
[ 9009.523781] usb 3-2.4.1: config 1 has an invalid interface number: 20 but max is 5
[ 9009.523784] usb 3-2.4.1: config 1 has no interface number 1
[ 9009.523786] usb 3-2.4.1: config 1 has no interface number 4
[ 9009.523788] usb 3-2.4.1: config 1 has no interface number 5
[ 9009.531745] usb 3-2.4.1: New USB device found, idVendor=1199, idProduct=68c0, bcdDevice= 3.18
[ 9009.531755] usb 3-2.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9009.531759] usb 3-2.4.1: Product: WP7608
[ 9009.531761] usb 3-2.4.1: Manufacturer: Sierra Wireless, Incorporated
[ 9009.674189] qcserial 3-2.4.1:1.0: Qualcomm USB modem converter detected
[ 9009.674404] usb 3-2.4.1: Qualcomm USB modem converter now attached to ttyUSB1
[ 9009.705089] qcserial 3-2.4.1:1.2: Qualcomm USB modem converter detected
[ 9009.705271] usb 3-2.4.1: Qualcomm USB modem converter now attached to ttyUSB2
[ 9009.737094] qcserial 3-2.4.1:1.3: Qualcomm USB modem converter detected
[ 9009.737536] usb 3-2.4.1: Qualcomm USB modem converter now attached to ttyUSB3
[ 9009.769206] qmi_wwan 3-2.4.1:1.8: cdc-wdm1: USB WDM device
[ 9009.778504] qmi_wwan 3-2.4.1:1.8 wwan0: register 'qmi_wwan' at usb-0000:05:00.3-2.4.1, WWAN/QMI device, be:28:bd:51:5a:5a
[ 9009.784257] cdc_ether 3-2.4.1:1.19 usb0: register 'cdc_ether' at usb-0000:05:00.3-2.4.1, CDC Ethernet Device, 46:20:ae:c5:20:d4
[ 9009.813310] cdc_ether 3-2.4.1:1.19 enx4620aec520d4: renamed from usb0
Thanks a lot for that tip, I can connect now again via SSH.
Unfortunately, my filesystem changes for testing are still there. Hence, AT!NVRESTORE and AT!NVBACKUP are presumably not the recovery mechanism for the filesystem?
So far I could not reproduce it, that is the reason why I played around with NVRESTORE and RMARESET. It happened once, probably caused by a series of brown outs, that the content of the filesystem was lost but the legato app still existed. This is what I would like to avoid, I do not want to lose the content of the filesystem in any case.
