My LS 300 is reboot with following log entries, but if i disconnect the ethernet it will stay on and everything seems to work fine.
any ideas?
Jan 1 00:21:57 info ALEOS_WAN_SCR: AT+CGREG shows not registered
Jan 1 00:22:03 info ALEOS_WAN_linkmon: Current RSSI=-125.
Jan 1 00:22:03 info ALEOS_WAN_linkmon: Network State is now Connecting To Network
Jan 1 00:22:04 info ALEOS_WAN_SCR: direct IP Wrapper rtn 0
Jan 1 00:22:07 info ALEOS_WAN_RMON: Rmon set lock
Jan 1 00:22:07 info ALEOS_WAN_RMON: RADIO-TYPE:GSM
Jan 1 00:22:07 info ALEOS_WAN_RMON: Auto-rescan set to ENABLED
Jan 1 00:22:08 info ALEOS_WAN_RMON: Error: Air Server not available 5- SLEEPING.
Jan 1 00:22:09 alert ALEOS_EVENTS_dpRptGen: Exiting due to a change in config data. row->id=11302
Jan 1 00:22:09 info ALEOS_WAN_RMAN: PDPRadioManager
Jan 1 00:22:09 info ALEOS_WAN_RMAN: currentState = AutoPdpOff
Jan 1 00:22:10 info ALEOS_WAN_RMAN: radioModule = SL8092
Jan 1 00:22:10 info ALEOS_WAN_RMAN: startupMode = 3
Jan 1 00:22:10 info ALEOS_WAN_RMAN: isRadioPassThruEnabled = 0
Jan 1 00:22:11 info ALEOS_WAN_RMAN: P10AutoPdpOff::nextState: trying to establish connection, launching start_directIP
Jan 1 00:22:11 info ALEOS_WAN_RMAN: PDPRadioManager
Jan 1 00:22:11 info ALEOS_WAN_RMAN: currentState = AutoConnecting
Jan 1 00:22:11 info ALEOS_WAN_RMAN: radioModule = SL8092
Jan 1 00:22:11 info ALEOS_WAN_RMAN: startupMode = 3
Jan 1 00:22:11 info ALEOS_WAN_RMAN: isRadioPassThruEnabled = 0
Jan 1 00:22:12 info ALEOS_WAN_SCR: CELLTECH is GSM, waiting for modem_start_lock
Jan 1 00:22:13 info ALEOS_WAN_linkmon: Current RSSI=-125.
Jan 1 00:22:13 info ALEOS_WAN_linkmon: Network State is now Not Connected - Waiting for Activity
Jan 1 00:22:18 info ALEOS_WAN_RMON: Error: Air Server not available 0- SLEEPING.
Jan 1 00:22:28 alert ALEOS_SYSTEM_Cmdexe: Country Code notified 232 default 0
Jan 1 00:22:28 info ALEOS_WAN_RMON: Rmon unset lock
Jan 1 00:22:28 info ALEOS_WAN_RMON: main: Temperature is 51
Jan 1 00:22:29 info ALEOS_WAN_RMON: 1st status 4, lock NOTSET, block NOTSET ^M
Jan 1 00:22:29 err ALEOS_WAN_RMON: SWI_NOTIFY_OMADM_Config notiy failed 600
Jan 1 00:22:29 err ALEOS_WAN_RMON: SWI_NOTIFY_OMADM_NI_Alert notiy failed 600
Jan 1 00:22:29 info ALEOS_WAN_RMON: Service Type: EDGE
Jan 1 00:22:29 info ALEOS_WAN_RMON: Clearing Service Quality Alarm
Jan 1 00:22:29 info ALEOS_WAN_RMON: waitForACMIMessages: Waiting for messages from SMSProc
Jan 1 00:22:29 err ALEOS_WAN_RMON: SwiGetDeviceTime() failed with error code=600
Jan 1 00:22:29 info ALEOS_WAN_RMON: waitForACMIMessages: Msg received from /cm
Jan 1 00:22:29 info ALEOS_WAN_RMON: MSCIID 1548 data
Jan 1 00:22:29 info ALEOS_WAN_RMON: MSCIID 1549 data
Jan 1 00:22:29 info ALEOS_WAN_RMON: MSCIID 1550 data
Jan 1 00:22:29 info ALEOS_WAN_RMON: MSCIID 65008 data 0
Jan 1 00:22:29 info ALEOS_WAN_RMON: MSCIID 2159 data 0
Jan 1 00:22:29 info ALEOS_WAN_RMON: rmon: Received CSM response.
Jan 1 00:22:29 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:22:29 info ALEOS_WAN_RMON: notification_callback: SMS Received
Jan 1 00:22:31 info ALEOS_WAN_linkmon: New voice coverage state 1
Jan 1 00:22:40 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:22:41 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:22:41 info ALEOS_WAN_RMON: Service Type: EDGE
Jan 1 00:22:41 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:22:56 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:22:56 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:22:56 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:23:12 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:23:13 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:23:13 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:23:15 info ALEOS_EVENTS_dpRptSend: Bufalloc- count 495 buffer of size 268 available
Jan 1 00:23:20 alert ALEOS_EVENTS_dpRptGen: dpRptGenProcessMSCIID: HIF Ready changed to 1
Jan 1 00:23:29 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:23:29 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:23:29 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:23:46 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:23:46 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:23:46 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:24:02 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:24:02 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:24:02 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:24:05 info ALEOS_WAN_NetServ: Tracking Enable State - Timer Event - check for test interval time out
Jan 1 00:24:05 info ALEOS_WAN_NetServ: sending icmp echo to 10.43.126.1 over br0, seq num 0
Jan 1 00:24:05 info ALEOS_WAN_NetServ: received correct ping response, seq 0.
Jan 1 00:24:05 info ALEOS_WAN_NetServ: Tracking In Test State - Test Done Event - timer restarts
Jan 1 00:24:18 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:24:19 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:24:19 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:24:34 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:24:35 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:24:35 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:24:51 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:24:52 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:24:52 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:25:07 info ALEOS_WAN_SCR: direct IP Wrapper trying AT.SCACT=1,1 = 0
Jan 1 00:25:08 info ALEOS_WAN_RMON: SWI_NOTIFY_CallStatus 0
Jan 1 00:25:08 info ALEOS_WAN_RMON: PLMN: T-Mobile, 23203
Jan 1 00:25:23 crit ALEOS_WAN_SCR: **** Resetting system. RM cannot get Data Connection.****
