Now it boot. thanks
Now I’m having issue with enabling power state(is low):
❯ mmcli -m any
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 838cb1e115e3a02df2cd05f5560b18832696681f
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: RC7620
| firmware revision: SWI9X07H_00.09.10.00 85890e jenkins 2023/09/25 03:16:56
| carrier config: default
| h/w revision: 1.0
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 353634110876389
System | device: /sys/devices/pci0000:00/0000:00:08.3/0000:e4:00.3/usb7/7-1/7-1.4/7-1.4.1
| drivers: qmi_wwan, qcserial
| plugin: sierra
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at), wwan0 (net)
Numbers | own: +4549321248
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: disabled
| power state: low
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, utran-1, utran-8, eutran-1, eutran-3, eutran-7,
| eutran-8, eutran-20, eutran-28
| current: egsm, dcs, utran-1, utran-8, eutran-1, eutran-3, eutran-7,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 353634110876389
| enabled locks: fixed-dialing
| packet service state: detached
3GPP EPS | ue mode of operation: csps-1
| initial bearer ip type: ipv4v6
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
In basic modemmanger log i get:
Mar 14 08:34:17 laped ModemManager[63014]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:01:00.0': not supported by any plugin
Mar 14 08:34:17 laped ModemManager[63014]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:03.1/0000:03:00.0/0000:04:04.0/0000:72:00.0': not supported by any plugin
Mar 14 08:34:29 laped cherrytree.desktop[53262]: [2024-03-14 08:34:29.717] [ ] [debug] autosave no need
Mar 14 08:34:35 laped ModemManager[63014]: <info> [device /sys/devices/pci0000:00/0000:00:08.3/0000:e4:00.3/usb7/7-1/7-1.4/7-1.4.1] creating modem with plugin 'sierra' and '5' ports
Mar 14 08:34:35 laped ModemManager[63014]: <warn> [plugin/sierra] could not grab port ttyUSB1: Cannot add port 'tty/ttyUSB1', unhandled port type
Mar 14 08:34:35 laped ModemManager[63014]: <info> [base-manager] modem for device '/sys/devices/pci0000:00/0000:00:08.3/0000:e4:00.3/usb7/7-1/7-1.4/7-1.4.1' successfully created
Mar 14 08:34:35 laped ModemManager[63014]: <warn> [modem0/sim0] couldn't load GID1: Couldn't read data from UIM: QMI protocol error (16): 'NotProvisioned'
Mar 14 08:34:35 laped ModemManager[63014]: <warn> [modem0/sim0] couldn't load GID2: Couldn't read data from UIM: QMI protocol error (16): 'NotProvisioned'
Mar 14 08:34:36 laped ModemManager[63014]: <warn> [modem0] couldn't load supported assistance data types: LOC service: general failure
Mar 14 08:34:36 laped ModemManager[63014]: <info> [modem0] state changed (unknown -> disabled)
Mar 14 08:34:36 laped NetworkManager[2659]: <info> [1710401676.0953] manager: (cdc-wdm0): new Broadband device (/org/freedesktop/NetworkManager/Devices/18)
Mar 14 08:34:36 laped NetworkManager[2659]: <info> [1710401676.0957] device (cdc-wdm0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 14 08:34:36 laped NetworkManager[2659]: <info> [1710401676.0959] device (cdc-wdm0): modem state 'enabling'
Mar 14 08:34:36 laped NetworkManager[2659]: <info> [1710401676.0961] device (cdc-wdm0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 14 08:34:36 laped ModemManager[63014]: <info> [modem0] state changed (disabled -> enabling)
Mar 14 08:34:36 laped ModemManager[63014]: <warn> [modem0] couldn't enable interface: 'Invalid transition'
Mar 14 08:34:36 laped ModemManager[63014]: <info> [modem0] 3GPP registration state changed (unknown -> unknown)
Mar 14 08:34:36 laped ModemManager[63014]: <info> [modem0] state changed (enabling -> disabled)
Mar 14 08:34:36 laped NetworkManager[2659]: <warn> [1710401676.1322] modem-broadband[cdc-wdm0]: failed to enable modem: GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Retry: Invalid transition
Could it be something like FCC unlock?
I tried calling:
❯ sudo qmicli -d /dev/cdc-wdm0 --dms-set-fcc-authentication
error: couldn't set FCC authentication: QMI protocol error (94): 'NotSupported'
Also tried to enable the fcc unlock scripts as mentioned in the modemmanager docs.
/etc/ModemManager/fcc-unlock.d🔒
❯ ll
lrwxrwxrwx@ - root root 14 Mar 08:16 03f0:4e1d -> /usr/share/ModemManager/fcc-unlock.available.d/03f0:4e1d
lrwxrwxrwx@ - root root 14 Mar 08:16 1eac -> /usr/share/ModemManager/fcc-unlock.available.d/1eac
lrwxrwxrwx@ - root root 14 Mar 08:16 1eac:1001 -> /usr/share/ModemManager/fcc-unlock.available.d/1eac:1001
lrwxrwxrwx@ - root root 14 Mar 08:16 2c7c -> /usr/share/ModemManager/fcc-unlock.available.d/2c7c
lrwxrwxrwx@ - root root 14 Mar 08:16 2c7c:030a -> /usr/share/ModemManager/fcc-unlock.available.d/2c7c:030a
lrwxrwxrwx@ - root root 14 Mar 08:16 105b -> /usr/share/ModemManager/fcc-unlock.available.d/105b
lrwxrwxrwx@ - root root 14 Mar 08:16 105b:e0ab -> /usr/share/ModemManager/fcc-unlock.available.d/105b:e0ab
lrwxrwxrwx@ - root root 14 Mar 08:16 413c:81a3 -> /usr/share/ModemManager/fcc-unlock.available.d/413c:81a3
lrwxrwxrwx@ - root root 14 Mar 08:16 413c:81a8 -> /usr/share/ModemManager/fcc-unlock.available.d/413c:81a8
lrwxrwxrwx@ - root root 14 Mar 08:16 1199 -> /usr/share/ModemManager/fcc-unlock.available.d/1199
.rwx------@ 775 root root 14 Mar 08:39 1199:68c0
lrwxrwxrwx@ - root root 14 Mar 08:16 1199:9079 -> /usr/share/ModemManager/fcc-unlock.available.d/1199:9079
ModemManager debug log in QMI shows:
ModemManager[64755]: <debug> [1710402289.938396] [modem0] autoconnect is already disabled
ModemManager[64755]: <debug> [1710402289.938426] [modem0] getting device operating mode...
ModemManager[64755]: <debug> [1710402289.938445] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 13
<<<<<< data = 01:0C:00:00:02:03:00:0B:00:2D:00:00...
ModemManager[64755]: <debug> [1710402289.938465] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 12
<<<<<< flags = 0x00
<<<<<< service = "dms"
<<<<<< client = 3
<<<<<< QMI:
<<<<<< flags = "none"
<<<<<< transaction = 11
<<<<<< tlv_length = 0
<<<<<< message = "Get Operating Mode" (0x002D)
ModemManager[64755]: <debug> [1710402289.940388] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:80:02:03:02:0B:00:2D:00:0B...
ModemManager[64755]: <debug> [1710402289.940418] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 3
<<<<<< QMI:
<<<<<< flags = "response"
<<<<<< tlv_length = 11
<<<<<< TLV:
<<<<<< type = "Result" (0x02)
<<<<<< length = 4
<<<<<< value = 00:00:00:00
<<<<<< translated = SUCCESS
<<<<<< TLV:
<<<<<< type = "Mode" (0x01)
<<<<<< length = 1
<<<<<< value = 01
<<<<<< translated = low-power
ModemManager[64755]: <debug> [1710402289.940463] [modem0] updating power state: 'on'...
ModemManager[64755]: <debug> [1710402289.940483] [modem0] Power indication registration request is sent
ModemManager[64755]: <debug> [1710402289.940503] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 17
<<<<<< data = 01:10:00:00:02:03:00:0C:00:01:00:04...
ModemManager[64755]: <debug> [1710402289.940526] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 3
<<<<<< QMI:
<<<<<< transaction = 12
<<<<<< tlv_length = 4
<<<<<< message = "Set Event Report" (0x0001)
<<<<<< TLV:
<<<<<< type = "Operating Mode Reporting" (0x14)
<<<<<< length = 1
<<<<<< value = 01
<<<<<< translated = yes
ModemManager[64755]: <debug> [1710402289.943212] [ttyUSB2/at] <-- '<CR><LF>OK<CR><LF>'
ModemManager[64755]: <debug> [1710402289.943267] [ttyUSB2/at] --> 'ATV1<CR>'
ModemManager[64755]: <debug> [1710402289.944205] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:02:03:02:0C:00:01:00:07...
ModemManager[64755]: <debug> [1710402289.944217] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 3
<<<<<< QMI:
<<<<<< tlv_length = 7
<<<<<< TLV:
<<<<<< length = 4
ModemManager[64755]: <debug> [1710402289.944241] [modem0] Power operation is pending
ModemManager[64755]: <debug> [1710402289.944252] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 17
<<<<<< data = 01:10:00:00:02:03:00:0D:00:2E:00:04...
ModemManager[64755]: <debug> [1710402289.944263] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 3
<<<<<< QMI:
<<<<<< transaction = 13
<<<<<< message = "Set Operating Mode" (0x002E)
<<<<<< TLV:
<<<<<< length = 1
<<<<<< value = 00
<<<<<< translated = online
ModemManager[64755]: <debug> [1710402289.944277] [modem0] Starting timeout for indication receiving for 10 seconds
ModemManager[64755]: <debug> [1710402289.948297] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:02:03:02:0D:00:2E:00:07...
ModemManager[64755]: <debug> [1710402289.948339] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 3
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< value = 01:00:3C:00
<<<<<< translated = FAILURE: InvalidTransition
ModemManager[64755]: <debug> [1710402289.948399] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 17
<<<<<< data = 01:10:00:00:02:03:00:0E:00:01:00:04...
ModemManager[64755]: <debug> [1710402289.948420] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 3
<<<<<< QMI:
<<<<<< transaction = 14
<<<<<< TLV:
<<<<<< length = 1
<<<<<< value = 00
<<<<<< translated = no
ModemManager[64755]: <debug> [1710402289.948452] [modem0] couldn't update power state: Invalid transition
ModemManager[64755]: <debug> [1710402289.948464] [modem0] attempting fcc unlock...
ModemManager[64755]: <debug> [1710402289.948542] [fcc unlock dispatcher] singleton created
ModemManager[64755]: <debug> [1710402289.950821] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 20
<<<<<< data = 01:13:00:80:02:03:02:0E:00:01:00:07...
ModemManager[64755]: <debug> [1710402289.950855] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 19
<<<<<< flags = 0x80
<<<<<< client = 3
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
ModemManager[64755]: <debug> [1710402289.952920] [ttyUSB2/at] <-- '<CR><LF>OK<CR><LF>'
ModemManager[64755]: <debug> [1710402289.952997] [ttyUSB2/at] --> 'AT+CMEE=1<CR>'
ModemManager[64755]: <debug> [1710402289.967595] [ttyUSB2/at] <-- '<CR><LF>OK<CR><LF>'
ModemManager[64755]: <debug> [1710402289.967672] [ttyUSB2/at] --> 'ATX4<CR>'
ModemManager[64755]: <debug> [1710402289.969553] [modem0] couldn't run FCC unlock: fcc unlock operation finished with status 1
ModemManager[64755]: <debug> [1710402289.969565] [modem0] updating power state: 'on'...
ModemManager[64755]: <debug> [1710402289.969578] [modem0] Power indication registration request is sent
ModemManager[64755]: <debug> [1710402289.969594] [/dev/cdc-wdm0] sent message...
So do you also have any ideas on this subject?
