hello,
thanks to for your help. i’m confused to not be clear but i’m a little lost equally with this device… i will try to clarify
dmesg | grep usb give me this
dmesg | grep "usb"
[ 1.429425] usbcore: registered new interface driver usbfs
[ 1.429507] usbcore: registered new interface driver hub
[ 1.429665] usbcore: registered new device driver usb
[ 1.433166] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.433178] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.433187] usb usb1: Product: UHCI Host Controller
[ 1.433194] usb usb1: Manufacturer: Linux 3.14-2-686-pae uhci_hcd
[ 1.433201] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.435400] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.435410] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.435418] usb usb2: Product: UHCI Host Controller
[ 1.435426] usb usb2: Manufacturer: Linux 3.14-2-686-pae uhci_hcd
[ 1.435434] usb usb2: SerialNumber: 0000:00:1d.1
[ 1.452286] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.452296] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.452304] usb usb3: Product: EHCI Host Controller
[ 1.452312] usb usb3: Manufacturer: Linux 3.14-2-686-pae ehci_hcd
[ 1.452319] usb usb3: SerialNumber: 0000:00:1d.7
[ 1.505939] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.505950] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.505957] usb usb4: Product: UHCI Host Controller
[ 1.505967] usb usb4: Manufacturer: Linux 3.14-2-686-pae uhci_hcd
[ 1.505975] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.820170] usb 3-5: new high-speed USB device number 3 using ehci-pci
[ 1.953725] usb 3-5: config 1 has an invalid interface number: 12 but max is 5
[ 1.953738] usb 3-5: config 1 has an invalid interface number: 13 but max is 5
[ 1.953748] usb 3-5: config 1 has an invalid interface number: 13 but max is 5
[ 1.953757] usb 3-5: config 1 has no interface number 4
[ 1.953765] usb 3-5: config 1 has no interface number 5
[ 1.955814] usb 3-5: New USB device found, idVendor=1199, idProduct=68a3
[ 1.955823] usb 3-5: New USB device strings: Mfr=4, Product=3, SerialNumber=5
[ 1.955829] usb 3-5: Product: MC7710
[ 1.955835] usb 3-5: Manufacturer: Sierra Wireless, Incorporated
[ 1.955840] usb 3-5: SerialNumber: 358178041667322
[ 2.324274] usb 1-2: new low-speed USB device number 2 using uhci_hcd
[ 2.535135] usb 1-2: New USB device found, idVendor=413c, idProduct=2106
[ 2.535150] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.535158] usb 1-2: Product: Dell QuietKey Keyboard
[ 2.535165] usb 1-2: Manufacturer: Dell
[ 3.370119] usbcore: registered new interface driver usbserial
[ 3.370192] usbcore: registered new interface driver usbserial_generic
[ 3.370263] usbserial: USB Serial support registered for generic
[ 3.373327] usbcore: registered new interface driver sierra
[ 3.373409] usbserial: USB Serial support registered for Sierra USB modem
[ 3.377201] usb 3-5: Sierra USB modem converter now attached to ttyUSB0
[ 3.378153] usb 3-5: Sierra USB modem converter now attached to ttyUSB1
[ 3.378953] usb 3-5: Sierra USB modem converter now attached to ttyUSB2
[ 3.381035] usb 3-5: Sierra USB modem converter now attached to ttyUSB3
[ 3.381873] usb 3-5: Sierra USB modem converter now attached to ttyUSB4
[ 3.384938] usb 3-5: Sierra USB modem converter now attached to ttyUSB5
[ 3.388492] usbcore: registered new interface driver cdc_ether
[ 3.643896] usbcore: registered new interface driver usbhid
[ 3.643906] usbhid: USB HID core driver
[ 3.652850] input: Dell Dell QuietKey Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-2/1-2:1.0/0003:413C:2106.0001/input/input6
[ 3.666842] hid-generic 0003:413C:2106.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell QuietKey Keyboard] on usb-0000:00:1d.0-2/input0
ls -l /sys/bus/usb-serial/devices
lrwxrwxrwx 1 root root 0 août 27 12:01 ttyUSB0 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.0/ttyUSB0
lrwxrwxrwx 1 root root 0 août 27 12:01 ttyUSB1 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.1/ttyUSB1
lrwxrwxrwx 1 root root 0 août 27 12:01 ttyUSB2 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.2/ttyUSB2
lrwxrwxrwx 1 root root 0 août 27 12:01 ttyUSB3 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.3/ttyUSB3
lrwxrwxrwx 1 root root 0 août 21 13:23 ttyUSB4 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.12/ttyUSB4
lrwxrwxrwx 1 root root 0 août 27 12:01 ttyUSB5 -> ../../../devices/pci0000:00/0000:00:1d.7/usb3/3-5/3-5:1.13/ttyUSB5
root@MonitorUndef:~# dmesg | grep 1199
so if i understand all my serial ports are created sierra module seems to do error :
dmesg | grep sierra
[ 3.373478] sierra 3-5:1.0: Sierra USB modem converter detected
[ 3.377284] sierra 3-5:1.1: Sierra USB modem converter detected
[ 3.378236] sierra 3-5:1.2: Sierra USB modem converter detected
[ 3.379030] sierra 3-5:1.3: Sierra USB modem converter detected
[ 3.381122] sierra 3-5:1.12: Sierra USB modem converter detected
[ 3.383113] sierra 3-5:1.13: Sierra USB modem converter detected
[ 5.132084] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
[ 5.132292] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
[ 5.132488] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
[ 5.132684] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
[ 5.154430] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
[ 5.154638] sierra ttyUSB4: sierra_submit_rx_urbs: submit urb failed: -8
but when i launch a micom with : minicom -D /dev/ttyUSB3
- if i use shortcut ctrl^a immediatly the status is disconnected…
- if i try a command, i can’t pass any command and hangs up until i kill the process…
and cat /sys/bus/usb-serial/drivers/sierra/new_id returns nothing…
thanks for help,
regards,
Damien
