I am trying to get the RC7620-1 Modem working on an android system. We are using Android 7.1 and are having a large degree of trouble using this modem.
In QMI Mode we are not able to get any sort of connection, it appears to have found the sim itself, but no outside connection is made.
We have confirmed that the modem works, we have tested the Modem in AT mode, and have received all the APN data, but still no data connection. We also tried tricking the HL Drivers to work with this modem, and we also where able to get sim signal, and APN info, but no data connection.
I will provide of logcat -b radio information below, but any help regarding this issue would be greatly appreciated.
03-08 10:39:42.954 5079 5079 D RILD : **RIL Daemon Started** 03-08 10:39:42.954 5079 5079 D RILD : **RILd param count=7** 03-08 10:39:42.991 5079 5079 W RILD : RIL_SAP_Init not defined or exported in /system/lib/libsierra-ril.so: undefined symbol: RIL_SAP_Init 03-08 10:39:42.991 5079 5079 D RILD : RIL_Init argc = 6 clientId = 0 03-08 10:39:42.992 5079 5079 I use-Rlog/RLOG-RIL: Entering RIL_Init.. 03-08 10:39:42.995 5079 5079 I use-Rlog/RLOG-RIL: Opening tty device automatically 03-08 10:39:42.995 5079 5079 I use-Rlog/RLOG-RIL: Using network interface wwan0 as primary data channel. 03-08 10:39:42.995 5079 5079 I use-Rlog/RLOG-RIL: Client id received 0 03-08 10:39:42.995 5079 5079 I use-Rlog/RLOG-RIL: RIL_Signalinit 03-08 10:39:42.996 5079 5079 I use-Rlog/RLOG-RIL: >>> voice feature enabled 1 03-08 10:39:42.996 5079 5079 I use-Rlog/RLOG-RIL: >>> persist.sierra.notification NOT set: debug radio notifcation disabled 03-08 10:39:42.999 5079 5079 I use-Rlog/RLOG-RILQAPI: starting swi_osapisdkprocesscreate 03-08 10:39:44.008 5079 5079 I use-Rlog/RLOG-RILQAPI: SDK Pid set 03-08 10:39:44.009 5079 5079 D use-Rlog/RLOG-RIL: #devices: 1 03-08 10:39:44.009 5079 5079 D use-Rlog/RLOG-RIL: deviceNode: /dev/qcqmi0 03-08 10:39:44.009 5079 5079 D use-Rlog/RLOG-RIL: deviceKey: 00000000000000 03-08 10:39:44.010 5079 5079 D use-Rlog/RLOG-RIL: 03-08 10:39:44.010 5079 5079 D use-Rlog/RLOG-RIL: QCWWAN2kConnect found device 03-08 10:39:44.094 5079 5079 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:44.095 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:44.095 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:44.095 5079 5079 I use-Rlog/RLOG-RIL: Read device type from property persist.radio.module 03-08 10:39:44.219 5079 5079 D use-Rlog/RLOG-RIL: registerNewSMSCallbackQMI:: entered 03-08 10:39:44.470 5079 5079 D use-Rlog/RLOG-RIL: registerVoiceCallbackQMI:: entered 03-08 10:39:44.524 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:44.554 5079 5079 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:44.554 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:44.554 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:44.554 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:44.554 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:44.586 5079 5079 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:44.586 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:44.586 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:44.586 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:44.586 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:44.618 5079 5079 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:44.618 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:44.618 5079 5079 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:44.618 5079 5079 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:44.618 5079 5079 D use-Rlog/RLOG-RIL: registerUSSDNotificationCallbackQMI:: entered 03-08 10:39:44.618 5079 5079 D use-Rlog/RLOG-RIL: registerUSSDReleaseCallbackQMI:: entered 03-08 10:39:44.619 5079 5079 D use-Rlog/RLOG-RIL: registerVoiceOrigUSSDNoWaitIndCallbackQMI:: entered 03-08 10:39:44.619 5079 5079 D use-Rlog/RLOG-RIL: registerVoiceOrigUSSDNoWaitIndCallbackQMI:: SetUSSDNoWaitIndicationCallback Success 03-08 10:39:44.705 669 774 I RILJ : Couldn't find 'rild' socket; retrying after timeout 03-08 10:39:44.714 5079 5079 D use-Rlog/RLOG-RIL: registerQmiNasDDTMIndication:: entered 03-08 10:39:44.718 5079 5079 D use-Rlog/RLOG-RIL: registerQmiNasDDTMIndication:: SetDDTMPrefIndicationCallback Success 03-08 10:39:44.718 5079 5101 I use-Rlog/RLOG-RIL: queueRunner starting! 03-08 10:39:44.718 5079 5079 D RILD : RIL_Init rilInit completed 03-08 10:39:44.718 5079 5079 I RILC : SIM_COUNT: 1 03-08 10:39:44.718 5079 5079 E RILC : RIL_register: RIL version 12 03-08 10:39:44.718 5079 5079 I RILC : s_registerCalled flag set, 1 03-08 10:39:44.718 5079 5079 I RILC : Start to listen RIL_SOCKET_1 03-08 10:39:44.719 5079 5079 D RILD : RIL_Init RIL_register completed 03-08 10:39:44.719 5079 5079 D RILD : RIL_register_socket completed 03-08 10:39:44.719 5079 5079 D RILD : RIL_Init starting sleep loop 03-08 10:39:44.720 5079 5101 I use-Rlog/RLOG-RILSCAN: USB write endpoint 3 is /dev/ttyUSB3 03-08 10:39:44.721 5079 5101 I use-Rlog/RLOG-RIL: queueRunner: AT port detected on /dev/ttyUSB3 and validated 03-08 10:39:44.721 5079 5101 I use-Rlog/RLOG-RILSCAN: USB write endpoint 3 is /dev/ttyUSB3 03-08 10:39:44.722 5079 5101 I use-Rlog/RLOG-RILSCAN: USB write endpoint 1 is /dev/ttyUSB1 03-08 10:39:44.723 5079 5101 I use-Rlog/RLOG-RILSCAN: USB write endpoint 2 is /dev/ttyUSB2 03-08 10:39:44.724 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for VOICE_REGISTRATION_STATE 03-08 10:39:44.724 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for DATA_REGISTRATION_STATE 03-08 10:39:44.724 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for SIGNAL_STRENGTH 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for OPERATOR 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for QUERY_NETWORK_SELECTION_MODE 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for GET_IMSI 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for DEVICE_IDENTITY 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for GET_IMEI 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for GET_IMEISV 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for BASEBAND_VERSION 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-AT: at_open started 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-AT: initializeAtContext: initializing at context 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-AT: Initialized new AT Context! 03-08 10:39:44.725 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:44.725 5079 5103 I use-Rlog/RLOG-AT: readerLoop started 03-08 10:39:44.737 5079 5101 I use-Rlog/RLOG-AT: AT(14)> ATE0Q0V1 03-08 10:39:44.737 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(a): o 03-08 10:39:44.740 5079 5103 I use-Rlog/RLOG-AT: AT(14)< ATE0Q0V1 03-08 10:39:44.741 5079 5103 I use-Rlog/RLOG-AT: AT(14)< OK 03-08 10:39:44.741 5079 5101 D use-Rlog/RLOG-AT: pausing.. 03-08 10:39:44.991 5079 5101 I use-Rlog/RLOG-AT: --- ATE0Q0V1 03-08 10:39:44.991 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:44.991 5079 5101 I use-Rlog/RLOG-AT: AT(14)> ATE0Q0V1 03-08 10:39:44.991 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(b): o 03-08 10:39:44.994 5079 5103 I use-Rlog/RLOG-AT: AT(14)< OK 03-08 10:39:44.994 5079 5101 I use-Rlog/RLOG-AT: --- AT+CMEE=1 03-08 10:39:44.994 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:44.994 5079 5101 I use-Rlog/RLOG-AT: AT(14)> AT+CMEE=1 03-08 10:39:44.994 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(b): o 03-08 10:39:45.003 5079 5103 I use-Rlog/RLOG-AT: AT(14)< OK 03-08 10:39:45.003 5079 5101 I use-Rlog/RLOG-AT: ---Modem unlock command 03-08 10:39:45.003 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:45.003 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(b): o 03-08 10:39:45.579 5079 5101 E use-Rlog/RLOG-RIL: initializeCommon error by AT!UNLOCK command 03-08 10:39:45.579 5079 5101 I use-Rlog/RLOG-AT: --- AT!BCRECOVERTEST=0 03-08 10:39:45.579 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:45.579 5079 5101 I use-Rlog/RLOG-AT: AT(14)> AT!BCRECOVERTEST=0 03-08 10:39:45.579 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(b): o 03-08 10:39:45.581 5079 5103 I use-Rlog/RLOG-AT: AT(14)< ERROR 03-08 10:39:45.581 5079 5101 I use-Rlog/RLOG-AT: --- AT^MODE=0 03-08 10:39:45.581 5079 5101 I use-Rlog/RLOG-AT: at_port_setup started 03-08 10:39:45.581 5079 5101 I use-Rlog/RLOG-AT: AT(14)> AT^MODE=0 03-08 10:39:45.581 5079 5103 D use-Rlog/RLOG-AT: readline received cmd(b): o 03-08 10:39:45.587 5079 5103 I use-Rlog/RLOG-AT: AT(14)< OK 03-08 10:39:45.587 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:45.614 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:45.614 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:45.614 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:45.614 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:45.615 5079 5101 I use-Rlog/RLOG-RIL: initializeChannelUMTS() 03-08 10:39:45.630 5079 5093 D use-Rlog/RLOG-RIL: nasSigInfoCallback invoked 03-08 10:39:45.646 5079 5101 I use-Rlog/RLOG-RIL: initializeChannelUMTS: powerMode=0 03-08 10:39:46.099 5079 5093 D use-Rlog/RLOG-RIL: Received SysInfo callback 03-08 10:39:46.422 5079 5093 D use-Rlog/RLOG-RIL: SLQSSetServingSystemCB Registration State: 0 03-08 10:39:46.422 5079 5093 D use-Rlog/RLOG-RIL: CS Attach State: 2 03-08 10:39:46.422 5079 5093 D use-Rlog/RLOG-RIL: PS Attach State: 2 03-08 10:39:46.422 5079 5093 D use-Rlog/RLOG-RIL: Selected Network: 0 03-08 10:39:46.423 5079 5093 D use-Rlog/RLOG-RIL: radioInterfaceList[0]: 0 03-08 10:39:46.426 5079 5103 I use-Rlog/RLOG-AT: AT(14)< +CREG: 0 03-08 10:39:46.426 5079 5103 I use-Rlog/RLOG-AT: AT(14)< +CGREG: 0 03-08 10:39:46.650 5079 5101 I use-Rlog/RLOG-RIL: initializeChannelUMTS: powerMode=6 03-08 10:39:46.650 5079 5101 I use-Rlog/RLOG-RIL: DHCP: 0, 03-08 10:39:46.650 5079 5101 I use-Rlog/RLOG-RIL: initializePrioChannel() 03-08 10:39:46.654 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:46.686 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:46.686 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:46.686 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:46.686 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:46.686 5079 5101 E use-Rlog/RLOG-RIL: Looping the requestQueue! 03-08 10:39:46.695 5079 5101 D use-Rlog/RLOG-RIL: requestSignalStrengthQMI_r12 RadioInterface[0]=0 03-08 10:39:46.695 5079 5101 D use-Rlog/RLOG-RIL: requestSignalStrengthQMI_r12 RadioInterface[1]=0 03-08 10:39:46.702 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: updating cache for SIGNAL_STRENGTH 03-08 10:39:46.710 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for VOICE_REGISTRATION_STATE 03-08 10:39:46.710 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for DATA_REGISTRATION_STATE 03-08 10:39:46.710 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for SIGNAL_STRENGTH 03-08 10:39:46.711 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for OPERATOR 03-08 10:39:46.711 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for QUERY_NETWORK_SELECTION_MODE 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: getServingNetworkQMI registrationState : 0 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: CSDomain : 2 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: PSDomain : 2 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: RAN : 0 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: radioIfacesSize : 1 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: radioIfaces[0] : 0 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: roamingInd : 255 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: MCC : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: MNC : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: Name : 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: Lac : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: CellID : 4294967295 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: SystemID : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: NetworkID : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: BasestationID : 65535 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: BasestationLatitude : 4294967295 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: BasestationLongitude : 4294967295 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: concSvcInfo : 255 03-08 10:39:46.711 5079 5101 D use-Rlog/RLOG-RIL: PRLInd : 255 03-08 10:39:46.711 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:46.742 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:46.742 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:46.742 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:46.742 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:46.742 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:46.774 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:46.774 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:46.774 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:46.774 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:46.774 5079 5101 D use-Rlog/RLOG-RIL: switchTechnologyDualMode no need to switch 03-08 10:39:46.774 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:46.807 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:46.807 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:46.807 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:46.807 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:46.807 5079 5101 D use-Rlog/RLOG-RIL: getRadioTechCDMA radioIface=0 03-08 10:39:46.807 5079 5101 D use-Rlog/RLOG-RIL: getRadioTechCDMA networkType=0 03-08 10:39:46.807 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: updating cache for VOICE_REGISTRATION_STATE 03-08 10:39:46.807 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:46.838 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:46.838 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:46.838 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:46.838 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:46.838 5079 5101 D use-Rlog/RLOG-RIL: getRadioTechCDMA radioIface=0 03-08 10:39:46.839 5079 5101 D use-Rlog/RLOG-RIL: getRadioTechCDMA networkType=0 03-08 10:39:46.839 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: updating cache for DATA_REGISTRATION_STATE 03-08 10:39:46.846 5079 5101 D use-Rlog/RLOG-RIL: requestSignalStrengthQMI_r12 RadioInterface[0]=0 03-08 10:39:46.846 5079 5101 D use-Rlog/RLOG-RIL: requestSignalStrengthQMI_r12 RadioInterface[1]=0 03-08 10:39:46.854 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: updating cache for SIGNAL_STRENGTH 03-08 10:39:48.706 669 774 I RILJ : (0) Connected to 'rild' socket 03-08 10:39:48.706 5079 5080 I RILC : libril: new connection to RIL_SOCKET_1 03-08 10:39:48.706 5079 5080 I RILC : RIL Daemon version: Sierra Ril V7.1.11.0_ARM_32 QMI 03-08 10:39:48.706 669 774 D RILJ : [UNSL]< UNSOL_RIL_CONNECTED {12} [SUB0] 03-08 10:39:48.707 669 774 D RILJ : [2804]> RADIO_POWER off [SUB0] 03-08 10:39:48.708 669 774 D RILJ : [2805]> RIL_REQUEST_CDMA_SET_SUBSCRIPTION_SOURCE : 0 [SUB0] 03-08 10:39:48.709 5079 5101 E use-Rlog/RLOG-RIL: processRequest: RADIO_POWER 03-08 10:39:48.709 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for VOICE_REGISTRATION_STATE 03-08 10:39:48.709 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for DATA_REGISTRATION_STATE 03-08 10:39:48.709 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for SIGNAL_STRENGTH 03-08 10:39:48.709 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for OPERATOR 03-08 10:39:48.709 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for QUERY_NETWORK_SELECTION_MODE 03-08 10:39:48.709 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:48.710 669 774 D RILJ : setCellInfoListRate: 2147483647 [SUB0] 03-08 10:39:48.710 669 774 D RILJ : [2806]> RIL_REQUEST_SET_CELL_INFO_LIST_RATE [SUB0] 03-08 10:39:48.711 669 774 D RILJ : [UNSL]< UNSOL_RESPONSE_RADIO_STATE_CHANGED RADIO_OFF [SUB0] 03-08 10:39:48.711 669 669 D SST : mDeviceShuttingDown=false, mDesiredPowerState=true, getRadioState=RADIO_OFF, mPowerOffDelayNeed=true, mAlarmSwitch=false, mRadioDisabledByCarrier=false 03-08 10:39:48.717 669 808 D Dcc : DccDefaultState: msg.what=EVENT_RIL_CONNECTED mRilVersion=12 03-08 10:39:48.728 669 669 D RILJ : [2807]> RADIO_POWER on [SUB0] 03-08 10:39:48.732 669 669 D RILJ : [2808]> OPERATOR [SUB0] 03-08 10:39:48.733 669 669 D RILJ : [2809]> DATA_REGISTRATION_STATE [SUB0] 03-08 10:39:48.734 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.734 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.734 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.734 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:48.735 669 669 D RILJ : [2810]> VOICE_REGISTRATION_STATE [SUB0] 03-08 10:39:48.736 669 669 D RILJ : [2811]> QUERY_NETWORK_SELECTION_MODE [SUB0] 03-08 10:39:48.738 669 669 D RILJ : [2812]> BASEBAND_VERSION [SUB0] 03-08 10:39:48.739 669 669 D RILJ : [2813]> GET_IMEI [SUB0] 03-08 10:39:48.740 669 669 D RILJ : [2814]> GET_IMEISV [SUB0] 03-08 10:39:48.741 669 669 D RILJ : [2815]> RIL_REQUEST_GET_RADIO_CAPABILITY [SUB0] 03-08 10:39:48.742 669 669 D RILJ : [2816]> RIL_REQUEST_START_LCE [SUB0] 03-08 10:39:48.761 669 669 D DCT : [0]onRadioAvailable 03-08 10:39:48.766 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.766 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.766 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.766 5079 5101 E use-Rlog/RLOG-RIL: processRequest: CDMA_SET_SUBSCRIPTION_SOURCE 03-08 10:39:48.766 5079 5101 E use-Rlog/RLOG-RIL: processRequest: SET_UNSOL_CELL_INFO_LIST_RATE 03-08 10:39:48.766 5079 5101 E use-Rlog/RLOG-RIL: processRequest: RADIO_POWER 03-08 10:39:48.766 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for VOICE_REGISTRATION_STATE 03-08 10:39:48.766 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for DATA_REGISTRATION_STATE 03-08 10:39:48.766 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for SIGNAL_STRENGTH 03-08 10:39:48.767 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for OPERATOR 03-08 10:39:48.767 5079 5101 I use-Rlog/RLOG-RIL: swiril_cache_set: clearing cache for QUERY_NETWORK_SELECTION_MODE 03-08 10:39:48.767 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:48.774 669 774 D RilRequest: [2804]< RADIO_POWER error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret= 03-08 10:39:48.780 669 774 D RilRequest: [2805]< RIL_REQUEST_CDMA_SET_SUBSCRIPTION_SOURCE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.781 669 774 D RilRequest: [2806]< RIL_REQUEST_SET_CELL_INFO_LIST_RATE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.798 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.799 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.799 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.799 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:48.831 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.831 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.831 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: processRequest: OPERATOR 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: processRequest: DATA_REGISTRATION_STATE 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: processRequest: VOICE_REGISTRATION_STATE 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: processRequest: QUERY_NETWORK_SELECTION_MODE 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: processRequest: BASEBAND_VERSION 03-08 10:39:48.831 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:48.832 669 774 D RilRequest: [2807]< RADIO_POWER error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret= 03-08 10:39:48.832 669 774 D RilRequest: [2808]< OPERATOR error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.833 669 774 D RilRequest: [2809]< DATA_REGISTRATION_STATE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.834 669 774 D RilRequest: [2810]< VOICE_REGISTRATION_STATE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.834 669 774 D RilRequest: [2811]< QUERY_NETWORK_SELECTION_MODE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:48.834 669 669 D SST : EVENT_POLL_STATE_NETWORK_SELECTION_MODE 03-08 10:39:48.862 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.862 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.862 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.862 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:48.894 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.894 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.894 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.894 5079 5101 E use-Rlog/RLOG-RIL: processRequest: GET_IMEI 03-08 10:39:48.894 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:48.895 669 774 D RilRequest: [2812]< BASEBAND_VERSION error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret= 03-08 10:39:48.926 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.926 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.926 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.926 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:48.958 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.958 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.958 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.958 5079 5101 E use-Rlog/RLOG-RIL: processRequest: GET_IMEISV 03-08 10:39:48.958 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:48.959 669 774 D RilRequest: [2813]< GET_IMEI error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret= 03-08 10:39:48.990 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:48.990 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:48.990 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:48.990 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:49.022 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:49.023 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:49.023 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:49.023 5079 5101 E use-Rlog/RLOG-RIL: processRequest: RIL_REQUEST_GET_RADIO_CAPABILITY 03-08 10:39:49.023 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: info invalid, initialize again 03-08 10:39:49.023 669 774 D RilRequest: [2814]< GET_IMEISV error: com.android.internal.telephony.CommandException: GENERIC_FAILURE ret= 03-08 10:39:49.054 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:49.054 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:49.054 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:49.054 5079 5101 E use-Rlog/RLOG-RIL: getFirmwareInfoTechQMI: Info invalid after initFirmwareInfoQMI() 03-08 10:39:49.086 5079 5101 D use-Rlog/RLOG-RIL: initFirmwareInfoQMI: SLQSGetFirmwareInfo() failed 11 03-08 10:39:49.086 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnGsmDevice=1 03-08 10:39:49.086 5079 5101 I use-Rlog/RLOG-RIL: telephony.lteOnCdmaDevice=0 03-08 10:39:49.086 5079 5101 E use-Rlog/RLOG-RIL: processRequest: <unknown request> 03-08 10:39:49.101 669 774 D RILJ : Faking RIL_REQUEST_GET_RADIO_CAPABILITY response using 1 [SUB0] 03-08 10:39:49.101 669 774 D RILJ : [2815]< RIL_REQUEST_GET_RADIO_CAPABILITY {mPhoneId = 0 mVersion=1 mSession=0 mPhase=0 mRadioAccessFamily=1 mLogicModemId= mStatus=1} [SUB0] 03-08 10:39:49.102 669 774 D RilRequest: [2816]< RIL_REQUEST_START_LCE error: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE ret= 03-08 10:39:49.107 669 669 D GsmCdmaPhone: EVENT_GET_RADIO_CAPABILITY: phone rc: {mPhoneId = 0 mVersion=1 mSession=0 mPhase=0 mRadioAccessFamily=1 mLogicModemId= mStatus=1} 03-08 10:39:49.107 669 669 D Phone : config LCE service failed: com.android.internal.telephony.CommandException: RADIO_NOT_AVAILABLE
