Is it happening at all protocol?
HTTP?FTP?TCP?
Did you disconnect the USB cable?
HTTP?FTP?TCP?
Hi @jyijyi
We are using FTP and USB and the result is the same.
i remember i saw error when connecting USB cable in Windows PC…
HTTP?FTP?TCP?
Hi @jyijyi
I am trying to connect in Linux. Now I can’t receive files using ftp.
Can ftp receive zip files?
I don’t see there is “+KFTP_IND: 1,1” which means successful connection to FTP
how about
AT+KFTPRCV=1,“dummy_file.txt”,0
why do you use …“test_001m.zip”
didn’t you should use comma?
Hi @jyijyi ,
Thanks for your reply.
The server only provide .zip file for download.
So you mean the command only can receive .txt ?
i mean this:
Hi @jyijyi
Sorry,I made a rookie mistake.
Now I connect.
But where can I find my received file or path.
It should appear like this:
AT+KFTPRCV=1,,,"dummy_file.txt",0
CONNECT
11111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
maybe it is in binary and you cannot see it?
Hi @jyijyi ,
If I want to find the file where can I find the file ? Not only display in terminal.
it only displays in terminal
Hi @jyijyi
What is +KFTP_ERROR: 1,-1 that "-1 "means?
I try to connect ftp but it responds +KFTP_ERROR: 1,-1.
why did you connect successfully previously?
Anything different?
Hi @jyijyi
The previous problem is solved.Thanks
I have a new problem with sending ftp, it responds to connect but can’t stop.
Do I need to do something first?
