larry1
1
I have a question about RC7620.
I want to use AT command to connect FTP
Command is below:
- at+kftpcfg=1,“ftp.speed.hinet.net”,“ftp”,“ftp”,21,1
- at+kftpcnx=1
but I got error code
+CME ERROR: 921
+KFTP_ERROR: 1,2
I don’t know why. Please help me thanks.
jyijyi
2
did you test in UART without USB connection?
larry1
3
Hi @jyijyi ,
Thanks for your reply.
We can not connect to internet by UART.
We check value AT+CSQ but the result is 99.
jyijyi
4
have you checked AT!GSTATUS?
Then are you using Windows or linux for your testing with USB?
larry1
6
I tested it by using windows.
jerry1
8
@jyijyi
I’m Larry’s colleague.
Yes we try at+cfun=1,but still can not connect to internet by UART.
jyijyi
9
what is AT!GSTATUS? after AT+CFUN=1
jyijyi
11
I don’t see problem with UART and without USB connection:
AT+KCNXCFG=1,“GPRS”,“smartone”,"",""
+KFTPCFG: 1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,1,0
+KFTP_IND: 1,1
jerry1
12
Hi @jyijyi
I try the same command but respond +CME ERROR: 3.
jyijyi
13
seems you need to type manually for character “”
jerry1
14
Hi @jyijyi
I try again.Still have some problem.
jyijyi
15
did you enter
AT+KCNXCFG=1,“GPRS”,“APN”,"",""
larry1
16
Hi @jyijyi ,
We use AT+KCNXCFG=1,“GPRS”,“internet”,"","" it looks fine.
But we use AT+KFTPCNX=1 then got the result is 911.
So what should I do for download or upload test file ?
And other question How can I query ftp server ?
jyijyi
17
no problem is found here
is it happening on other network?
jerry1
18
Hi @jyijyi
We only have this network. We can use this network to connect internaet on Windows.
jerry1
20
Hi @jyijyi
Confirmed baud rate is 115200 but still error.
