I have an RC7611 module deployed on an ARM device that bricked mid-upgrade using the qmi-firmware-upgrade tool.
Right now when booted normally (TP1 low) - the module just bootloops about 1-2secs of coming up.
Each time it fails around here:
ModemManager[1949]: [/dev/cdc-wdm0] Checking version info (25 retries)...
[ 98.108201] usb 1-1: USB disconnect, device number 6
[ 98.115479] qcserial_1 ttyUSB0: Qualcomm USB modem converter now disconnected from ttyUSB0
[ 98.124472] qcserial 1-1:1.0: device disconnected
[ 98.128973] qcserial_1 ttyUSB1: usb_wwan_open: submit read urb 0 failed: -19
[ 98.136679] qcserial_1 ttyUSB1: usb_wwan_open: submit read urb 1 failed: -19
[ 98.143771] qcserial_1 ttyUSB1: usb_wwan_open: submit read urb 2 failed: -19
[ 98.150919] qcserial_1 ttyUSB1: usb_wwan_open: submit read urb 3 failed: -19
[ 98.160455] qcserial_1 ttyUSB1: Qualcomm USB modem converter now disconnected from ttyUSB1
ModemManager[1949]: <info> [base-manager] port [ 98.169497] qcserial 1-1:1.2: device disconnected
ttyUSB0 released by device '/sys[ 98.179696] qcserial_1 ttyUSB2: Qualcomm USB modem converter now disconnected from ttyUSB2
I managed to get the 3 /dev/ttyUSB0-2 ports and I can briefly access the AT port and get the following info. After a lot of retries, I was able to get the following out of the module:
ati
Model: RC7611
Revision: SWI9X07H_00.08.20.00 d73df7 jenkins 2021/10/14 00:48:45
IMEI: 352138110582626
IMEI SV: 18
FSN: 6M1474352210B0
+GCAP: +CGSM
AT!BCFWUPDATESTATUS
!BCFWUPDATESTATUS: UNKNOWN
AT!ERR
MODEM APPS
00 01 seccrypt 00208
01 01 rfuser 00192
02 01 gpstask 04166
03 01 rfant 01351
04 01 bshw_gpi 00185
05 01 gsnvif 00858
06 02 sio 00502
07 01 sio 00720
AT!GCDUMP
No crash data available
AT!IMAGE?
ModemManager[1922]: <warn> [ttyUSB0/probe] failed to parse QCDM version info command result: -7
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 1
Active FW image is at slot 255
PRI FF GOOD 0 0 0 001.075_000 00.08.20.00_ATT
PRI FF GOOD 0 0 0 001.046_000 00.03.03.00_GENERIC
PRI FF GOOD 0 0 0 000.027_000 00.03.03.00_SIERRA
Max PRI images: 50
I’ve attempted to the following also:
AT!RMAREST=1 - don’t work (ERROR, AT!ENTERCND=… also ERROR, not enough time)
AT!BOOTHOLD=1 - don’t work, continues to bootloop
AT!WFWUPD… - not sure what file I would be flashing. I’m not sure what Documentation goes with this command. I can xmodem stuff but I need some more info.
I am able to assert TP1 on the module to enter bootloader mode and see the single serial port over USB (I’m guessing this is the DM Port).
Based on reading various posts, I came across this page: https://source.sierrawireless.com/resources/legato/wpxxxxrecoveryprocedure/#sthash.KFRjLFjm.dpbs
which seems to provide the tools on x86 machines to recovery the module once you can boot it into bootloader mode.
Problem is, my module is deployed on an ARM(aarch64) device, and I don’t have an easy way to get the module to talk to the PC.
Is there a arm/aarch64 build of the swiflash tool that I can run on our ARM processor to do this recovery? Is that even the right tool? I also see something about swicve referenced in other threads.
I also can have access to the real UART port if there’s another way to reprogram the module by that path.
Any information would be helpful.
Thanks in advance.
Ben
