Hi to all,
I am little bit confusion about memory of Q2686G.
I am using flashwrite and flashread functions.In datasheet each flash object max 30kb.
i want to know max size of flash in Q2686G and memory details.
regards
nagendra
Hi to all,
regards
nagendra
Hiya,
There’s two different types of flash on the Q2686.
There’s the (configuration) flash - accessed by the adl_flhXXX() functions. According to the ADL User guide, there’s about 128k of flash; of which there can only be 2000 object identifiers; the maximum size of data pointed to by each object identifier is roughly 30k; and the flash can be erased/written around 100,000 times. This flash can be written and re-written without any special operations by the user
There’s also the ADL flash - used when downloading applications and is generally used for bulk data storage. This flash is accessed by the adl_adXXX() functions. This area can be resized by using one of the AT+WOPEN commands, and requires special care to erase/re-write.
Check out the FLASH and APPLICATION & DATA STORAGE sections of the ADL user guide for more info.
ciao, Dave
Thanks , doubt cleared but which version adl user guide is best ?
can u give the document link of Q2686G?
Thanks is advance
nagendra
Well, obviously, the one that matches the version of ADL that you are actually using
8)
