Problems updating EM7411 firmware with multiple modules attached by USB
I am trying to update the firmware of EM7411 modules in a production test environment that will have one or two EM7411 modules connected at any given time.
I am trying to use the fdt2 tool (from here) to do so. I am able to update via the fdt tool when only a single module is connected. I can use a command line like:
fdt2.exe -f SWI9X50C_01.14.05.00.cwe –multi
to update a unit. I have tried this with just a single module connected and it works.
I used the advice from this forum post Multiple module firmware update - #7 by Wiviacom to determine the -usbport value, however it simply hangs. Is the -usbhub tag a required partner tag to the -usbport? If so how do I determine the -usbhub value?
When using the command line to sepcify the USB port, is seems to hang:
c:\CAT7>fdt2.exe -f SWI9X50C_01.14.03.00.cwe -multi -usbport 44
FDT version: 1.0.1806.0
Awaiting suitable port or adapter …
Enabling selective suspend …
Firmware download failed.
Primary error code: 82 - Failed in checking modem mode.
Secondary error code: 5 - Neither NDIS adapter nor serial port is available.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 25125 ms.
Images downloaded:
Press Enter to continue …
Hi @brandon.conway
Please try it with fdt2.exe -f filename.cwe -usbport44 -multi
It is OK for me.
Note: It should be -usbport44 instead of -usbport 44 (whitespace removed).
Help to tick “Solutions” if your question is answered.
Are you sure about the no space between the command switch and the value? It looks like the developers making fdt2.exe in windows crossed the streams for the -usbport and -usbhub switches with like 3+ different methodologies. The cleanest looking log filename and arguments read in occur when you do add a space. Pretty sure the no space option sets the value to -1 and just picks the first device it finds to flash.
This fdt2.exe tool badly needs an update and a simple gui for production programming would be extremely helpful. Have up to 4 firmwares to built a “config” to flash and then have all the modems detected in the system show up (8+) and a flash all button. It would then ideally flash them all in parallel, or maybe do 2 or 4 at a time. Even 1 at a time would be fine.
