I’m trying to flash multiple firmware images (and PRI) onto an EM9191 module with fdt2.exe but it will only flash them on firmware slot “1”, and “2” If I flash one image at a time, it keeps overwriting the last one, thus not allowing me to swap PRI with !IMPREF as I’m guessing they are getting orphaned.
TLDR: What is the syntax to flash multiple images and PRI and have it use all firmware image slots, NOT just slot “1” so that I can swap PRI images at will?
Command I’m using:
fdt2.exe -d g5k -resettimeout 3 -timeout 15 -f SWIX55C_03.04.03.00-001.cwe SWIX55C_01.07.23.00-001.cwe SWIX55C_01.07.13.00-005.cwe SWIX55C_03.04.03.00-001_GENERIC_030.012_000.nvu SWIX55C_01.07.23.00-001_VERIZON_012.019_000.nvu SWIX55C_01.07.13.00_ATT_012.007_002.nvu SWIX55C_01.07.13.00_TMO_001.005_003.nvu -mi -impref SWIX55C_03.04.03.00-001.cwe SWIX55C_03.04.03.00-001_GENERIC_030.012_000.nvu -force -log logs
Command outcome:
Prior to running commands over and over again, lol:
Here you see the multiple PRI exist after running the above command, but there are only two FW image slots being populated with an image. It’s skipping, or overwriting, SWIX55C_01.07.23.00-001.cwe. This making the Verizon PRI an orphan.
Maybe My fdt2.exe command syntax is off somewhere?
halp!
