Problems Getting EM9191 Working with M.2 to USB Adapters
Thank you so much for your help! With your guidance, I’ve managed to get the device recognized by the computer, which was a major step forward. It appears that pin 22 for VBUS_SENSE was key.
Now, I am trying to get the EM9191 module to work on a Raspberry Pi Compute Module 4. When connected, it’s detected by the system and I’ve succeeded in connecting to the module’s serial interface, which is great. However, I’ve run into a challenge: although I can communicate with the module and even obtain an IP address using AT commands, this address doesn’t seem to be passed on to the Raspberry Pi’s internet interface. A wwan interface is created but it remains inactive and without an IP address.
I would greatly appreciate any suggestions you might have or guidance on what steps I should take next. What should I check or adjust to ensure that the wwan interface becomes active and correctly receives IP details via DHCP?
Thank you very much for your response and for your ongoing support.
