Problem using MC7304 on compliant MiniPCI Express slot
I want to use MC7304 on a fully compliant MiniPCI Express slot. So far, I have found two conflict in hardware pins:
Pin 11: is defined as VCC_MSM18_DIG +1.8 V reference out on MC7304 and on PCI express it is defined as pci_clk_n.
Pin 33: is defined as SYSTEM_RESET_N on MC7304 and on PCI express it is defined as pci_tx_p.
I might have missed more conflicts which I hope not. Does anyone know a work around for this problem? Maybe deactivate those pins in the FW?
Regards,
Allan
Which document are you referring to?
According to the AirPrime MC Series Dev Kit Quick start guide , Pin 11 corresponds to VCC_MSM18_DIG and Pin 33 corresponds to RESET_N.
You can refer the Dev kit schematic view for more information.
Link to the document: http://source.sierrawireless.com/resources/airprime/development_kits/airprime_mc_series_development_kit_board_quick_start_guide/
Regards,
Rex
Hi Rex,
Correct as you replied and that is the problem. According to PCIe standard, Pin 11 and 33 are defined as pci_clk_n and pci_tx_p, respectively. This is causing conflict with Sierra MC7304 module.
Hello All,
Have a nice day and please to meet you all. I would like to give some input here where I currently installed MC7304 on Lenovo X220/X220T running Windows 7 Pro 64 bit and already upgraded to Windows 10 Pro 64 bit where all running fine.
Forget all about where you only need to taped #20 pin (or #18 & #20 pins).
Regards,
Zainul
Hello All,
I don’t what really “problems” ?. For me, I had installed MC7304 on X220/X220T running Windows 7 Pro 64 bit and updated to Windows 10 Pro 64 bit where both are working fine even can get full 4G LTE internet access. Pin #20 should be taped or inclusive of pin #10 (Wireless Disable (main RF radio)).
Regards,
Zainul
