mishac
November 3, 2008, 11:39pm
1
This application never seems to work, I always get “GPS fix not obtained yet”. However, I can get the Query_App application to work by following the user guide instructions. Has anyone got this demo to work or should I just not bother with it.
Cheers, Misha
waasiri
November 4, 2008, 12:27am
2
Hi misha
you missing a step I guess.
have you enabled the active antena ? without it you wont get a fix.
try this
Disable keypad :AT+WHCNF=0,0
Set IO 8 as output :AT+WIOM=8,1,0
Set IO 8 to LOW level to enable the antena: AT+WIOW=8,0
let me know how you go with this.
this sample works for me.
have you tried aiding sample ?
cheers
Asiri
mishac
November 4, 2008, 1:16am
3
Good idea, but executing the command “AT+WIOM=8,1,0” gives me a CME ERROR 3. What’s up?
BTW executing the command “AT+WIOM?” gives me an “OK” only
mishac
November 4, 2008, 1:54am
4
I managed to enter the following commands OK, but still no fix:
AT+WHCNF=0,0
AT+WIOM=1,“GPIO8”,1,0
AT+WIOW=“GPIO8”,0
waasiri
November 4, 2008, 10:28am
5
hi
which app is this sample app or query app ?
i know aiding query app doesnt work.
other two demo apps works fine but i had set the active antena pin.
mishac
November 4, 2008, 12:24pm
6
The QueryApp application works fine, but the Position_Retreival application does not. I used the same commands for both applications.
ok
that one takes while to get a fix, give it a good 10 minutes on target mode
cheers
mishac
November 5, 2008, 1:04am
8
No good - it didn’t get a fix when I left it running overnight
are you trying indoor ?
take it to open sky and give it a try.
mishac
November 5, 2008, 4:17am
10
The GPS module IS working, another demo, QueryApp, works with the same commands. So I’m pretty sure the demo is a dud.
waasiri
November 5, 2008, 4:39am
11
it works
but I am not sure I changed the code.
It needs more time than other one because this doesnt have aiding.
