Please help my actived CGPS
hai all
im using Fastrack Supreme 20
im using Aplication open at sdk v4.21.01
im downloads .dwl simple sample from cplugin
but error like this:
GPS Sample: Application Started
GPS Sample: GPS Core Initialisation Success
GPS Sample: GPS Fix not obtained yet
pleas hlpmy
tanks for hlp
Why do you call that an “error” :question:
It says, “GPS Fix not obtained yet” - it takes time to obtain a GPS fix, so you have to wait for it :exclamation:
Are you sure you aren’t just being impatient…? :wink:
how can otput
Longitude & Latitude i won see that
can gifemeopen at fan:
tanks
/* appli.c - Copyright Wavecom S.A. © 2006 /
DISCLAIMER OF WARRANTY /
This Software is provided free of charge on an ‘as is’ basis. No warranty is given /
by Wavecom S.A. in relation to the Software of the uses to which it may be put by you, /
the user, or its merchantability, fitness or suitability for any particular purpose /
or conditions; and/or that the use of the Software and all documentation relating /
thereto by the Licensee will not infringe any third party copyright or other /
intellectual property rights. Wavecom S.A. shall furthermore be under no obligation /
to provide support of any nature for the Software and the Documentation. /
LIMIT OF LIABILITY /
In no event shall Wavecom S.A. be liable for any loss or damages whatsoever or howsoever /
caused arising directly or indirectly in connection with this licence, the Software, /
its use or otherwise except to the extent that such liability may not be lawfully /
excluded. Notwithstanding the generality of the foregoing, Wavecom S.A. expressly /
excludes liability for indirect, special, incidental or consequential loss or damage /
which may arise in respect of the Software or its use, or in respect of other equipment /
or property, or for loss of profit, business, revenue, goodwill or anticipated savings. /
/* File : Appli.c /
Object : File containing code related to main application /
Date | Author | Revision | Description /
09.02.07 | Wavecom P | 1.0 | /
/* Headers */
#include “adl_global.h”
#include “CGpsCore.h”
#include “math.h”
/* Macros */
#define APP_ATCMD_UART ADL_PORT_UART1
#define APP_GPS_UART ADL_PORT_UART2
Mandatory variables /
wm_apmCustomStackSize /
const u16 wm_apmCustomStackSize = 4096;
Function : PrintCurrentFix /
Object : Get and print the current Fix /
Variable Name |IN |OUT|GLB| Utilisation /
void PrintCurrentFix()
app_GpsPosition_t CurPosition;
s8 sRet;
ascii RspBuffer[100];
/* Get the current position */
sRet = GetCurrentFix(&CurPosition);
if (sRet < 0)
	adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, "\r\nGPS Sample: GPS Fix not obtained yet\r\n");
	return;
/* Print the position on serial port */
/* Format==> Decimal degree */
wm_sprintf(RspBuffer, "\r\nGPS Sample: %0.06f %c, %0.06f %c\r\n",
                    fabs(CurPosition.Longitude),
                    CurPosition.dir[1],
                    fabs(CurPosition.Latitude),
                    CurPosition.dir[0]);
/* Send the buffer on serial */
adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, RspBuffer);
Function : appTimerhdl /
Object : Timer handler /
void appTimerhdl(u8 TimerId)
PrintCurrentFix();
Function : AppCbGpsHandler /
Object : Callback related to GPS related events /
void AppCbGpsHandler(u8 Event)
switch(Event)
case APP_CGPS_INIT_DONE:
		/* GPS init complete */
		adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, "\r\nGPS Sample: GPS Core Initialisation Success\r\n");
		/* Get and print the Fix */
		PrintCurrentFix();
		/* Start a timer to print the current Fix every 1 second */
		adl_tmrSubscribe ( TRUE, 10, ADL_TMR_TYPE_100MS, appTimerhdl );
	break;
	case APP_CGPS_INIT_FAILED:
		/* GPS init failed, send the same to user */
		adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, "\r\nGPS Sample: GPS Core Initialisation Failed\r\n");
	break;
	case APP_CGPS_FEATURE_NOT_ACTIVATED:
   		/* Feature not activated, inform the same to user */
   		adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, "\r\nGPS Sample: CGPS Feature not activated\r\n");
	break;
Function : adl_main /
Object : Customer application initialisation /
InitType | | | | Application start mode reason /
TRACE(( 2, “OAT_API_VERSION = %d”, OAT_API_VERSION ));
/* Init CGPS layer */
AppInitCoreGps (AppCbGpsHandler, APP_GPS_UART);
/* Send a response on AT command as other UART is dedicated to GPS */
adl_atSendResponsePort ( ADL_AT_RSP, APP_ATCMD_UART, "\r\nGPS Sample: Application Started\r\n");
You haven’t provided any additional information, and haven’t answered previous questions:
Hi ppl! I have the same problem - “GPS Fix not obtained yet”… I was waiting for 40 minutes, but answer was the same… Where can be the problem? (In addition to my DNA =))) )
Hi all,
I think you must enable some pins before using the first time, following this guide:
Config one time after download firmware or the first time run modem:
AT+WOPEN=0
AT+WOPEN=3
AT+WDWL
… Download Embedded appli
AT+CFUN=1
AT+WOPEN=1
AT+WHCNF=0,0
AT+WIOM=8,1,0
AT+WIOW=8,0
To debug:
AT+NMEA=1 (or = 0)
AT+CGPS = 2
AT+CONFIG=1 (To save and run always run appl)
(Can send SMS for PVT obtaining: INFO:“Password”:“Phonenumber” )
{Exp: INFO:CGPS[:telephone number]}
Hope help you,
ttt
Thanks trthaithong, but it’s still not working… The reply is “GPS FIX NOT ACHIEVED”. What is it means?
