One more AT+CPOF problem
I have a curious problem. I have develop a bord for the modules Q26xx that apparently work very well.
Except for one detail: running a simple “AT + CPOF” (in ADL adl_atCmdCreate(…)) the module doesn’t go to alarm mode.
It’s work only when the RTS (serial_1) is physically grounded or the serial is connected to the computer.
I found nothing in manuals. Someone has an idea?
Excuse my English.
Hi grabarski,
As I know about Power off the WCPU is:
" you must reset the ON/OFF signal and then send the AT+CPOF command to deregister from the network and switch off the WCPU"
ttt
You mean reset the ON/~OFF pin physically? Like put the ON/~OFF to ground or open?
Or would update the state that the OS “recorded” the pin?
Thank you for your reply.
Yes, you must reset ON/OFF pin physically, put ON/OFF pin to ground.
ttt
Yes, this procedure was already used to place the ON / OFF ~ to ground.
And is necessary also to put the RST SERIAL1 to ground. What happens is that sometimes the module not sleep, thus breaking a routine periodic readings.
