Octave ULPM failure
MangOH Yellow with FW 3.1.0-mangOH-0.
I could trigger MangOH Yellow to enter ULPM with AT!powermode=3 command.
But with Octave {‘util/ulpm/shutdown’: 1} command, MangOH Yellow won’t go into ULPM.
Can anyone help?
Hi jameshorng,
Could you please explain clearly about your Octave command? How can you input this command, via edge action or command stream?
Due to Octave {“util/ulpm/shutdown”:1} command failed to put MangOH Yellow into ULPM, I used AT!powermode=3 command through console port to test.
Please refer to the discussion in here Do MangOH Yellow support ULPM?
For Octave command, I click the send command icon in util/ulpm/shutdown section from dashboard and the Trigger button from popup.
From Dashboard device/detail, {“util/ulpm/shutdown”:1} command was send to MangOH Yellow.
On FX30S, I can put device into ULPM. But MangOH Yellow did not enter ULPM.
Hi James,
This is a known issue and an a ticket exists for engineering to address. I will update the ticket with your comments and will update this forum entry as updates occur.
I tested Octave with MangOH Yellow, FX30 (Ethernet) and FX30S (RS232). Only FX30S worked as expected.
Anyone know when this issue will be resolved?
is there an update regarding ULPM functionality?
This issue has been solved by FW 3.2.0.
That’s great. Thanks for the update. It looks like FW 3.1.0 is all that is available for the 7702 module now. When will 3.2.0 be released?
I tested ULPM on FX30/FX30S since last July. Haven’t checked on MangOH ever since. FW update for MangOH seems to be lagged. Need to ask SWIR when they will bring the FW up to date for MangOH.
Hi James,
Latest firmware will not be provided for MangOH Yellows. The Yellow hardware can continue to be used as a development kit for Octave use cases, relying on the latest firwmare versions: for that we recommend using the WP7702 builds on the MangOH Yellow hardware (Octave Edge Devices)
All new features and fixes will be included, the only limitations will be the absence of the Yellow specific sensors and LEDs
A.
