Hello All,
We have a fleet of Octave-based devices, where each device being deployed requires detailed custom configuration (e.g. changing the Modbus TCP addresses, the number of Modbus servers and other properties). The devices are pre-configured with some ‘standard’ blueprint thus, we only want to modify the above-mentioned properties per device. Therefore, changing via SSH connection to each device seems to be a good solution.
Thanks to this topic I discovered dhub CLI tool proposed for similar purpose. And it indeed works for submitting a configuration containing different IP address than the preconfigured one:
dhub push /app/modbus/config --json "some JSONifyed config"
Reading it back using dhub list /app/modbus/config returns exactly the config I programmed.
Nevertheless, Octave’s web app doesn’t reflect these changes (e.g. shows old Modbus TCP IP address) even after rebooting the device. Why is that? Can that be ignored?
I tried same sort of excercise with a virtual resource and a dummy variable (pre-initialized using the Octave web app) and I do confirm while dhub accepts new values Octave web app shows the old one. Interestingly, if I change the variable in the web app, dhub tool returns the new value.
Another little issue I wanted to address is when trying to use dhub push from json file it returns an error. For instance this call:
dhub push /app/modbus/config --file --json test_config.json
where test_config.json contents is:
{"buses":[{"ethname":"eth0","ipport":502,"name":"CCR5","ipaddr":"192.168.10.15","config":[{"slaves":[{"address":1,"name":"CCR5"}],"period":30,"groups":[{"number":14,"address":64,"name":"status","type":"HLD"}]}]},{"ethname":"eth0","ipport":502,"name":"CCR2","ipaddr":"192.168.10.12","config":[{"slaves":[{"address":1,"name":"CCR2"}],"period":30,"groups":[{"number":14,"address":64,"name":"status","type":"HLD"}]}]}]}
returns
Error failed to get file size test_config.json (LE_BAD_PARAMETER)
What could possibly be wrong here?
My system is:
- Device: FX30
- Firmware: 3.5.0
Thanks in advance,
Alex
