I have a little new problem. My modem is working correctly (it's a m1306b). It gets it's own IP, starts the bearer, etc, but when i try to access it using telnet (telnet x.x.x.x), i get this error: "Connecting to x.x.x.x...Could not open connection to the host, on port 23: Connection failed".
I know port 23 is telnet reserved port. I have tried to reach the modem with several computers, but all of them give me the same error. Can someone give me a hand on this? Thank you in advance .
Hi, thanks for the answer. I’m afraid I have no idea of what the problem is, could you explain that a little? I have very few experience with this kind of programming…
If you want to Telnet to your modem, then you must have something running in your modem to handle the Telnet protocol.
It’s just like if you were doing a dialup data call, and wanted to transfer a file using XMODEM - you would need an XMOMDEM handler running on your modem.
