Not able to ping using Airtel SIM card in EM7565 4G Module
When we insert Sierra Wireless SIM card to EM7565 Module, we are able to ping and its working fine.
We have connected this EM7565 Module to Nvidia Jetson Xavier Nx devkit.
We tried to insert AIRTEL SIM card instead of Sierra Wireless SIM card to EM7565 Module, we are not able to ping properly(i.e after sending 50 t0 60 packets it stopped pinging) and sometimes even not able ping.
Here is the ping log for reference
64 bytes from maa05s14-in-f4.1e100.net (142.250.76.68): icmp_seq=49 ttl=117 time=55.8 ms
64 bytes from maa05s14-in-f4.1e100.net (142.250.76.68): icmp_seq=51 ttl=117 time=148 ms
64 bytes from maa05s14-in-f4.1e100.net (142.250.76.68): icmp_seq=50 ttl=117 time=1149 ms
64 bytes from maa05s14-in-f4.1e100.net (142.250.76.68): icmp_seq=52 ttl=117 time=38.7 ms
^C
— www.google.com ping statistics —
112 packets transmitted, 52 received, 53% packet loss, time 112462ms
rtt min/avg/max/mdev = 37.839/138.426/1149.730/205.069 ms, pipe 2
nvidia@linux:~/Documents$ ping www.google.com
ping: www.google.com: Name or service not known
How about ping 8.8.8.8
Ping 8.8.8.8 is also not working
What is at!gstatus?
At+cgdcont?
At+cpin?
At+cgpaddr=1
At!uims?
sir, here are the AT commands
at
at+cgreg?
+CGREG: 0,5
at+cops?
+cops: 0,0,“IND airtel airtel”,7
at+cpin?
+CPIN: READY
at!gstatus?
!GSTATUS:
Current Time: 1092 Temperature: 25
Reset Counter: 1 Mode: ONLINE
LTE band: B1 LTE bw: 10 MHz
LTE Rx chan: 240 LTE Tx chan: 18240
LTE SSC1 state:NOT ASSIGNED
LTE SSC2 state:NOT ASSIGNED
LTE SSC3 state:NOT ASSIGNED
LTE SSC4 state:NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -68 PCC RxM RSRP: -99
PCC RxD RSSI: -96 PCC RxD RSRP: -132
Tx Power: – TAC: 21f9 (8697)
RSRQ (dB): -14.4 Cell ID: 00027321 (160545)
SINR (dB): -1.4
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“internet.sierrawireless.com”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at+cgpaddr=1
+CGPADDR: 1,100.73.208.34,36.1.73.0.22.238.215.121.0.2.0.2.157.71.36.138
at!uims?
!UIMS: 1
are you using SIM slot 2?
Yes. At present we are using Sim slot2
did you set the APN correctly?
I saw it is ”internet.sierrawireless.com"
When i trying to set APN
at+cgdcont: 1,“IPV4V6”,“www.airtelgprs.com”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
ERROR
how about
at+cgdcont=1,“IPV4”,“www.airtelgprs.com”
AT+CGDCONT= 1,“IP”,“airtelgprs.com”,“0.0.0.0”,0,0
Will check whether it is pinging or not
Thanks for your support. Now able to ping.
Can we use dual sims at a time? Is there any AT commands for that ?
Instead of changing sim slot1 to slot2.
I can only see AT!UIMS to switch SIM card
