Hi there!
Could you please assist me to get everything working?
I run Arch Linux. My SL6087 is being added as /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Aug 19 12:00 /dev/ttyACM0
initially it has been belonging to uucp group, but I use udev rule to change the group to dialout.
Also I saw the same issue here and tweaked /var/lock folder permissions so my user has r/w right to it.
ls -la /run/lock
total 4
drwxrwxr-x 5 root lock 120 Aug 19 12:00 .
drwxr-xr-x 22 root root 620 Aug 19 11:00 ..
-rw-rwxr-- 1 root lock 22 Aug 19 09:13 asound.state.lock
drwxrwxrwt 2 root lock 40 Aug 19 09:13 dmraid
drwxrwxr-x 2 root lock 40 Aug 19 09:13 lockdev
drwxrwxr-x 2 root lock 40 Aug 19 09:13 subsys
The user belongs to “lock” group (plus uucp and dialout
gid=100(users) groups=100(users),3(sys),5(tty),6(disk),7(lp),10(wheel),14(uucp),54(lock),90(network),91(video),92(audio),93(optical),95(storage),96(scanner),98(power),108(vboxusers),1000(dialout)
I’m able to connect to SL using minicom and to send AT commands but there is no any traces of the device in Target Management.
Seems like it’s just Java doesn’t see the device. I have rxtx-java installed though.
I know that DS supports Debian based distros only, but nonetheless, could you please help me out with the issue?
