No network connection
I have a problem with my Q2687 that it’s impossible to make a connection of the network.
Normally, when you turn on the module, it must connect to the network operator. But it doesn’t with mine.
I’ve tried 3 simcards of different operators, but none of them actually works.
What could be wrong? I was thinking about the pin, but this is disabled for the simcard.
at+creg?
+CREG: 1,2
Meaning:
1 = enable network registration code result code +CREG: <stat>
2 = not registered, ME currently searching for a new operator
So it can’t register … ?
at+cops?
+COPS: 1
Meaning manual operator selection
If I want to set the operator selection to automatic (=0), I get error:
at+cops=0
ERROR
Can someone help me out?
Thank you!
Alexander
EDIT
I have also another GSM module from siemens, and there it works well
at+cops?
+COPS: 0,0,"BEL PROXIMUS"
at+cops=?
+COPS: (2,"BEL PROXIMUS",,"20601"),(3,"B mobistar",,"20610"),(3,"BASE",,"20620")
,,(0-4),(0,2)
So I’m connected to BEL PROXIMUS after a few seconds.
Using the wavecom module, it doesn’t work?
I am also having a similar problem here.
You’re not alone! If I figure it out, I’ll let you know!
Scott
Thank you ScottG!
My local contact person is also looking for a solution.
Greetings
Alexander,
Look at my post here. This solved my problem. Hopefully it will work for you as well.
-Scott
This also solved my problem :smiley:
It was at 4,0 … and in Europa, it must be 5,0 …
Thank you for the help!
regards
