I just learned to work with a Camera using the RC7611 Chip to connect to the Verizon network, but I can’t get it to work.
Camera (connect USB to PC) starts up + connects to Wifi but I don’t see the WWAN0 interface.
The system parameters are as follows:
ls /dev |grep ttyUSB
ttyUSB0
ttyUSB1
ttyUSB2
qmicli --wds-get-packet-service-status -d /dev/cdc-wdm0
[/dev/cdc-wdm0] Connection status: ‘disconnected’
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --uim-get-card-status
[/dev/cdc-wdm0] Successfully got card status
Provisioning applications:
Primary GW: slot ‘1’, application ‘3’
Primary 1X: session doesn’t exist
Secondary GW: session doesn’t exist
Secondary 1X: session doesn’t exist
Slot [1]:
Card state: ‘present’
UPIN state: ‘not-initialized’
UPIN retries: ‘0’
UPUK retries: ‘0’
Application [1]:
Application type: ‘csim (4)’
Application state: ‘detected’
Application ID:
A0:00:00:03:43:10:02:F3:10:FF:FF:89:02:00:00:FF
Personalization state: ‘unknown’
UPIN replaces PIN1: ‘no’
PIN1 state: ‘not-initialized’
PIN1 retries: ‘0’
PUK1 retries: ‘0’
PIN2 state: ‘not-initialized’
PIN2 retries: ‘0’
PUK2 retries: ‘0’
Application [2]:
Application type: ‘isim (5)’
Application ID:
A0:00:00:00:87:10:04:F3:10:FF:FF:89:08:00:00:FF
PIN1 state: ‘disabled’
PIN1 retries: ‘3’
PUK1 retries: ‘10’
PIN2 retries: ‘0’
PUK2 retries: ‘0’
Application [3]:
Application type: ‘usim (2)’
Application state: ‘ready’
Application ID:
A0:00:00:00:87:10:02:F3:10:FF:FF:89:08:00:00:FF
Personalization state: ‘ready’
PIN1 retries: ‘3’
PUK1 retries: ‘10’
PIN2 state: ‘enabled-not-verified’
PIN2 retries: ‘3’
PUK2 retries: ‘10’
Application [4]:
Application type: ‘unknown (0)’
Application ID:
A0:00:00:00:63:50:4B:43:53:2D:31:35
PIN1 retries: ‘0’
PUK1 retries: ‘0’
PIN2 retries: ‘0’
PUK2 retries: ‘0’
Slot [2]:
Card state: ‘absent’
UPIN retries: ‘0’
UPUK retries: ‘0’
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wda-get-data-format
[/dev/cdc-wdm0] Successfully got data format
QoS flow header: no
Link layer protocol: ‘raw-ip’
Uplink data aggregation protocol: ‘disabled’
Downlink data aggregation protocol: ‘disabled’
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wds-start-network=“ip-type=4,apn=vzwinternet” --client-no-release-cid
error: couldn’t start network: QMI protocol error (14): ‘CallFailed’
call end reason (3): generic-no-service
verbose call end reason (3,2001): [cm] no-service
[/dev/cdc-wdm0] Client ID not released:
Service: ‘wds’
CID: ‘7’
qmicli -d /dev/cdc-wdm0 --nas-get-signal-strength
[/dev/cdc-wdm0] Successfully got signal strength
Current:
Network ‘none’: ‘-128 dBm’
RSSI:
ECIO:
Network ‘none’: ‘-2.5 dBm’
I would appreciate any help!
